828x audio glitches when plugging in USB MIDI Device
floriflocke
Post by floriflocke »
Hi guys,
we have a Motu 828x and are having real difficulty with a glitch (attached below) that is making our live set increasingly unstable and unreliable. We have upcoming shows so this is quite a worry.
After updating our Mac to El Capitan we get heavy audio glitches when plugging in a usb device while an Ableton project is open. (Running 9.5) These glitches didn't happen when Yosemite was installed, although random shorter glitches occurred from time to time as well but different to these.
We tried with every firmware and driver version, also the latest for OSX El Capitan as well as different MacBooks and USB devices incl. various hubs (Keyboards, Controller, etc.), using both thunderbolt and usb. The problem occurs in both Ableton Live and Logic Pro X and only with El Capitan installed and using the Motu. When using a Focusrite Scarlet 2i4 this problem did not occur which tells us it must be a problem with Motu itself.
https://www.dropbox.com/s/96ivi5qyyaeux ... h.m4a?dl=0
The glitch doesn't stop until switching the Interface on and of, or changing settings in the MOTU audio setup ( switching Clock Source to World Clock in and back to internal, Enable Core Audio Volume Controls, ...)
If you can think of anything to help, please let us know. Customer support has left us hanging.
Best,
Florian
SonidoEncarnado
Re: 828x audio glitches when plugging in USB MIDI Device
Post by SonidoEncarnado »
Hi, Im getting a similar problem with my Microbook ii,
simptoms: glitch similar to yours, play speed doubles,
Or, get cracks and latency increases.
I get this while im playing my ableton live performance set which consists of MacbookPro13, Yosemite, Ableton 9.2, Synth(wharfed rocket, MIDI triggered from ableton and audio coming back through Microbook ii to ableton.) and a couple of MIDI Controllers (launchControl and A&H K2)
getting a bus powered usb hub did't help.
I need to turn off Motu from Ableton Audio setting to stop this ••••.
It has actually occurred during my show...
You are running OS 10.11.4, right?
The latest OS update did address some USB issues but I suspect not all.
If nothing else works, can you buy a USB hub or two and keep everything plugged in all the time?
