Weird graphic in Mix Window...?
- cbergm7210
Notice the two vertical bars...anyone?
http://www.rfjmusic.com
Re: Weird graphic in Mix Window...?
Obviously a graphic bug. You can tell they are the level meters for a stereo track. Weird stuff like this can happen. When it does, I tickle the GUI by showing/hiding the track selector or resizing the window and move on. Unless you can figure out steps to reproduce this glitch and send it to MOTU, these things are tough to track down.
- cbergm7210
Yea, it's weird...no matter what I do it stays there. I close the sidebar and now it's on top of the faders, etc. Only happens every now and then since I went to DP 8.James Steele wrote:Obviously a graphic bug. You can tell they are the level meters for a stereo track. Weird stuff like this can happen. When it does, I tickle the GUI by showing/hiding the track selector or resizing the window and move on. Unless you can figure out steps to reproduce this glitch and send it to MOTU, these things are tough to track down.
I don't think I've ever seen this one, myself. Bizarre.cbergm7210 wrote:Yea, it's weird...no matter what I do it stays there. I close the sidebar and now it's on top of the faders, etc. Only happens every now and then since I went to DP 8.
- cbergm7210
Well, you are brighter than I. Didn't even realize that it was the stereo meter.James Steele wrote:I don't think I've ever seen this one, myself. Bizarre.cbergm7210 wrote:Yea, it's weird...no matter what I do it stays there. I close the sidebar and now it's on top of the faders, etc. Only happens every now and then since I went to DP 8.
Next time it happens, it might be interesting to see if you have a mixing board channel that is *missing* its level meters? Or... if you see level indicated on them and can figure out what track it might be associated with. You could try reinstalling DP 8.07 and see if this goes away, but that would be a shot in the dark.
Is it specific to one theme?
I had some graphic anomalies while using Voxengo Span some time ago. When the Span window was open and I moved it, it would leave some elements behind, just like your orphaned stereo meters. The thing is, once this happened, other anomalies would start to happen to DP's GUI, and only relaunching DP would make it go away. The problem went away with an update from Voxengo.
The reason I mention this is so you don't rule out the possibility of some plug-in causing the problem.
- cbergm7210
Well, I only use the Producer theme, so I could not be sure.bayswater wrote:Is it specific to one theme?
- cbergm7210
- philbrown
That is weird! Before you take any more drastic measures, have you tried simply changing themes? That might 'refresh' things graphically.
