Pitch automation?
- Tesionman
Pitch automation?
Howdy!
I want to automate the pitch of an audio file for effect purposes. For example: To make a pitch bend wheel effect on a soundbite.
Is this possible in DP?
cheers
cheers
Get Real Live Drum Tracks @ http://www.hugoribeiro.com
Macbook Pro | DP 10.13 | Motu 8Pre (x2) | Apogee Duet 2
Sonor Drums | Sabian Cymbals | Remo Drumheads | Vater Drumsticks
Re: Pitch automation?
Not with pitch automation, try the nano-sampler.
DP 10.13, OSX 10.13.6, MacPro 5.1 12 core, 48gigs RAM, 2408Mk3, 2408Mk2, 2 Fastlanes, 2-UAD2 solos, Machfive 2/3.2.1, MSI, BFD3
- Tesionman
Yeah, the Nanosampler has that pitch function although not very practical!kurtl wrote:Not with pitch automation, try the nano-sampler.
Thanks for your response.
cheers
Apple has a pitch-shift AU that is just part of their bread & butter set. I think it is called AUPitch. Should already be on your machine.
You can then run an automation lane to automate the pitch.
I used this to introduce wow & flutter into a "vintage" film track. It might do what you need.
To be clear, the audio file you want to pitch shift is not monophonic, right? i.e. not a vocal track, etc.
- Tesionman
That worked great!! Thanks!!! I never remember that I have those Apple plugs.stubbsonic wrote:Apple has a pitch-shift AU that is just part of their bread & butter set. I think it is called AUPitch. Should already be on your machine.
cheers
- Dwetmaster
AUPitch is a hidden Gem
- Tesionman
Its for two mono guitar tracks(Left & Right).Killahurts wrote:To be clear, the audio file you want to pitch shift is not monophonic, right? i.e. not a vocal track, etc.
I used the AUpitch on each track and automate how much I want it to pitch. Worked fine.
Cool! I always forget about the Apple built-in plugs.. will have to explore them someday.
- darrell
+1!stubbsonic wrote:I used this to introduce wow & flutter into a "vintage" film track. It might do what you need.
