I cannot update Motu MIDI XT firmware.
I have tried on OSX and windows, I have tried different xt's (i have 3) I have tried different usb cords. I'm at my whits end, what am I doing wrong. my daw sees the xt and i can use them so why can't the firmware upgrader? losing it here
Re: I cannot update Motu MIDI XT firmware.
Trying to get through on tech support but getting BUSY SIGNAL... NOT EVEN CALL WAITING?!
Does this apply to you?
http://www.motu.com/techsupport/technot ... changelog/
NOTE: These firmware updates are only applicable to MIDI Express XT units that have a serial number starting with ‘MXT’. Units that have a serial number starting with ‘MEXT’ or ‘MXXTU’ cannot be updated.
Earlier versions were only updatable by switching out a chip set. The replacement sets were discontinued in 2012 and are no longer available.
If you do have one that can be updated, I found this:
To boot your MIDI Express XT into a firmware update mode, connect the unit to your computer via USB, and Press and Hold the STRIPE button while powering the unit on. Follow the Firmware Updater's on-screen instructions.
Hmm, I didn't know there was another revision of the newer style models so my assumtion is that you are right (thanks for enlightening me). I say assumption because I guess the stickers on my units are all missing.
This is kind of frustrating by motu to have this happen on the newer style just like the older style.
When you power the unit on, it should display a firmware version. What is that number?
That should give a clue as to what version of the XT you have.
