Move wiper to selection start?
Hi all,
I was wondering if there was a quick way to get the playback wiper to jump to the start of a selection and stay there, so that I can then insert a marker precisely at the start of a soundbite. I'm trying to duplicate something I can do in PT, namely select a region, then immediately paste a marker at the start of it.
I guess another way of looking at it might be as the opposite to 'snap-soundbite-to-marker' - 'snap-marker-to-soundbite'.
Thanks in advance.
Jon
http://www.jonnicholls.com
DP 8.07, Mac OS 10.8.5, 2x2.8Ghz Quad-Core Intel Xeon, 16Gb RAM
Thanks in advance.
Jon
Re: Move wiper to selection start?
2
Command-4
Control-M
Spacebar
Command-4
Control-M
Spacebar
- Shooshie
Tim wrote:2
Command-4
Control-M
Spacebar
To expand a little on Tim's otherwise very precise reply, I think he got the Spacebar out of order. I can't make it work in that particular order.
Command-4 sends the cursor back to the beginning of the selection, then plays. If you hit the spacebar right after Command-M, it will stop when it gets to the beginning of the selection.
Control-M gives you the Marker, plus a dialog to name it. Actually, that may be my custom command. I think originally Control-M just gave you the marker, then I switched it to "New Marker with Options" because I like adding markers and naming them on the fly. It's easier for me to go down the list of markers and change their locations to the first beat of a measure than it is to go back and name them. I can name them within 8 bars before the next one, and get them pretty close to the beat. Either way, you get a marker when you click Control-M.
To clarify: Step one, Number pad '2' = Pause.
One can repeat clicking soundbites and making markers while in Pause, then Spacebar when done.
- Shooshie
Well, Duh on me! For some odd reason, I thought you were just being economical and saying "2 commands, as follows:" But of course you meant Pause. Slow on the uptake here, but glad you clarified. I have to admit I was thrown off-guard by the remote possibility that you were in error. You've restored my blind faith in The Tim!Tim wrote:To clarify: Step one, Number pad '2' = Pause.
Shoosh
- Dwetmaster
I use the command: "Set Memory and Play selection" for this. I have it setup to CTL-SHFT-Spacebar.
You enable Auto-Rewind.
You select the soundbite.
Hit CTL-SHFT-Spacebar
Hit spacebar a second time.
The playhead is now at the beginning of the selected soundbite.
I can't tell if this is what the posts suggest: After making a selection, Pause then Command-Spacebar will put the wiper at the selection start.
- Shooshie
It's Control-Spacebar for me, but I may have changed the default. I wish there was a marker to show custom keybindings, as I change so many of them that I never know if I'm telling someone MY binding or the default binding. Anyway, if Command-Spacebar doesn't work, try Control-Spacebar.dix wrote:I can't tell if this is what the posts suggest: After making a selection, Pause then Command-Spacebar will put the wiper at the selection start.
- philbrown
Both Command-4 and Control-Spacebar work the same way for me here, and I haven't changed any of these key bindings.Shooshie wrote:It's Control-Spacebar for me, but I may have changed the default. I wish there was a marker to show custom keybindings, as I change so many of them that I never know if I'm telling someone MY binding or the default binding. Anyway, if Command-Spacebar doesn't work, try Control-Spacebar.dix wrote:I can't tell if this is what the posts suggest: After making a selection, Pause then Command-Spacebar will put the wiper at the selection start.
Fantastic - thanks v much everyone!
Jon
Jon
