DP8 launch crash [OUCH!! UNRESOLVED]
[EDIT & UPDATE] Originally, all this trouble started with the installation of a new RME FF800 driver. But after a clean install and not installing any RME driver or attaching the interface, the trouble remains.
Five weeks in, and still haven't sorted it. AU's work perfectly in GarageBand. The DP launch crash is related to AU's in that after the crash happens, one or more AU's becomes "damaged" (at least as far as DP is concerned). Removing them allows DP to launch. But what causes the DP crash or AU damage is still quite unclear. Beginning to look at hardware as an issue.
There have been issues with DP8, AUs, and with the Fireface MIDI driver. But it is all unclear as to what the initial cause of the problems are. It could be that the DP crash is creating ripple effects. Very tricky one, this.
The thread contains lots of red herrings. As of 11/27/14 (Thanksgiving!) the cause is not known. Two clean installs and a very careful pruning of AU's has not solved it. Removing the RME FF800 from the equation did not solve it.
The next phase is to begin to test the SSD and RAM for problems. I've reset PRAM several times. But I haven't reset the SMC yet. Not sure now to do that on the RMBP as I think the battery might be glued in. Will look that up.
Re: DP8 crashes during launch (OS 10.9.5)
I would reinstall DP 8 and repair permissions first. If you still have the problem, yes, the RME driver is your likely suspect.
Thanks, Mike. I'll do that right away.
I did try reverting to the older RME driver, but that didn't fix it. (Ended up with it launching both old & new mixer apps, so I need to see if I can find an uninstaller as well.
I'll report back. Thanks!
Ok. I did a few iterations of re-installed DP 8.07, and re-installing either of the RME drivers (my previous one and the new one). I did restarts and permissions repairs after each attempt.
I also tried launching DP8 in 64-bit mode, but it crashed in the exact same way.
It looks like it finishes going through the plug-ins, finishing with Wah Pedal. Then it shows the menu bar for an instant, then it brings up the crash reporter.
Now I'm stuck and I didn't even jump on the Yosemite thing. I don't think I did anything risky.
BTW, when I repaired permissions both before and after installing the older & newer RME driver, these were the items listed both times:
Repairing permissions for “Macintosh HD”
Permissions differ on “System/Library/CoreServices/Feedback Assistant.app”; should be drwxr-xr-x ; they are lrwxr-xr-x .
Repaired “System/Library/CoreServices/Feedback Assistant.app”
Permissions differ on “Applications/Safari.app/Contents/Resources/Safari.help/Contents/Resources/index.html”; should be lrwxr-xr-x ; they are -rwxr-xr-x . Repaired “Applications/Safari.app/Contents/Resources/Safari.help/Contents/Resources/index.html”
Group differs on “Library/Audio/Plug-Ins/MAS”; should be 0; group is 80.
Permissions differ on “Library/Audio/Plug-Ins/MAS”; should be drwxr-xr-x ; they are drwxrwxr-x .
Repaired “Library/Audio/Plug-Ins/MAS”
Permissions repair complete
Have you started up holding the option key? If not, do so and select an option. I'd start with "safe" or whatever it's called and see if it launches. If not, shut all the plugs off and see if it still happens. If is does, then something must either be corrupted or installed incorrectly.
I tried using the Option "Disable All" but it still crashed.
Then I selected "safe" and that worked. PHEEEW!
Now I'll just need to see which of the plugs is corrupt or causing the problem.
Since disable all didn't fix it, I'm curious how to approach this. And what other things "Safe" mode provided.
I tried trashing all the DP prefs I could find (then re-installed DP).
I was hoping that if it scanned the AU's it might find something.
But it might be an MAS plug-in, or I guess it could be other stuff.
If "Disable All" didn't work, and "Safe" did, are there other things besides plug-ins that could be implicated?
More tests....
More tests....
You know there were a few updates to drivers in the past week?
The only driver I updated was for RME Fireface, and neither the old driver nor the new driver seem to have any affect on the issue-- since I know the crash seems to happen whether the device is connect or not.
And since I didn't update the OS, and I'm not using any other audio hardware (no MOTU hardware here)-- are there other new drivers I should either install or avoid (since I'm not on 10.10)?
I does seem a little tricky to figure out if it is a corrupt plug-in. It crashes when "all are disabled" and launches when the "safe" set is enabled.
I'm in over my head. I'll connect with MOTU Tech support on this.
Do you have a crash report that you can update to a techlink? If so, MOTU support is pretty good at seeing the conflict.
BTW, I would not have recommended reinstalling the driver after reinstalling DP 8.07. I have run into this often enough that I don't report it here. I have come to accept that some installers break paths in DP and reinstalling fixes them.
What are your installation security settings? If not Allow apps downloaded from • Anywhere, change them first. Not all installers generate the proper error but, if it should, it won't install everything properly.
Now, reinstall one of the drivers (the driver that worked?). Reinstall DP and repair permissions. See if you still have a problem.
Unless you did all that already. If so, go back to my opening question.
Thanks for the help, fellers. But I'm afraid the situation is devolving.
I made sure that the last steps were installing DP8, and repairing permissions.
The situation seems worse now. DP hangs in a non-responsive state much earlier in the launch. Holding Option no longer works because this crash is different & earlier (long before plugs start to load). The crash reporter doesn't automatically come up, I have to force-quit to see a OS level crash report.
Not that it matters, but this is with the older RME driver installed--but the FF800 was offline.
Poop. I guess I'll try to use GarageBand for the next few days. Poop!
Working with MOTU Support now. Just wanted to give an update.
I was able to launch DP under a new user acct I had created.
I am also able to OPTION-launch DP when I use the "safe" plugin set. Weirdly, I created a plug-in set with ALL plug-ins turned off (which it looks like they are all MAS plugs in the DP8/Preferences/Plugin manager), DP crashes when I choose that set. Actually, it did launch one time, but crashes every time after that.
I also moved all the plug-in preferences I could identify into a folder on my desktop, but that didn't fix anything.
- Shooshie
Hoo-boy. This is worrisome. If it can happen to you, it can happen to me.
Thanks for keeping us in the loop on this. It means having a reference if it DOES happen to any of us. That's what it's all about, so... thanks again. And sorry for what you're having to go through. I sure hope you get to the bottom of it soon.
Meanwhile, props to MOTU for getting you off dead-center and getting some movement happening again.
Shoosh
Shoosh
The process has been slow. And I'm trying to be patient as long spells of time go by between the tips I get from MOTU support.
The first snag was that all this time when it looked like I was sending crash reports to MOTU, apparently they are not getting them (even when I tried another email address). I didn't know where to look for DP's crash reports, and MOTU's support guy neglected to mention any paths in his short posts.
I looked in ~Library/Logs/DiagnosticReport and there were some crash logs from MIDIServer and mdworker from a few days ago. But there weren't nearly enough of them to correspond with all the crashes I've seen. I didn't see anything from DP or MOTU in there.
I looked in a few other places but didn't find any DP/MOTU crash things.
It would be possible to just create a new user and start working again. I'd need to move a bunch of projects to a folder that can be accessed by the other user acct. I guess that's ok. But it will remain to be seen what authorizations I've already hosed in this process. It'll be a few hours of that, as well.
- BKK-OZ
You said your problems started after the RME driver update - what do RME have to say? I don't use their kit, but maybe they have a forum where other users have experienced problems with that update?
Just a stab in the dark, I feel for you.
Cheers,
BK
- M Kaku
BK
- M Kaku
