424 card not seeing HD 192 anymore
sultanmakende
Post by sultanmakende »
After many support tickets with MOTU tech support I have reached a dead end.
Problem:
Mac Pro sees the card fine both in system report and Prefs/audio.
After connecting HD 192 to the card, I open MOTU PCI driver / connection app, but there is no communication with the HD 192.
I have done all the obvious such as change firewire cable, change PCI slot, re-install PCI driver
The HD 192 seems to fire up fine with the startup clock source search and all status lights showing.
MOTU tech support don't seem to be particularly bothered about trying to help me, just saying that they no longer manufacture or support the HD 192.
So what do I do, just throw away a $2,000 interface that is less than 10 years old?
This is bad for the environment, bad for business and bad for me!!
I have asked them to at least send me a circuit diagram, so that I can try and get it repaired but so far no response.
So all you potential MOTU hardware purchasers out there be careful and think twice about buying a MOTU hardware product.
In the mean time, if any kind soul out there might have access to a circuit diagram and/or any repair tips, I would be forever indebted. :surrender: :boohoo:
Re: 424 card not seeing HD 192 anymore
So, how old is it?
Open it up and burnish all internal connectors by disconnecting and reconnecting three times. If oxidation is the culprit, this will restore functionality. Look for evidence of a cold or cracked solder joint and touch up any that you see.
Sometimes the cable connector will crack or wear out. These can be replaced.
sultanmakende
Hi Mike, many thanks for the tip, I will try what you say.
I bought it new in 2005, so it's about 9 years old and had served me very well until recently.
I'm now living in Salvador, Brazil, not far from the ocean so I have a feeling that the salty air might be involved.
Do you know what is the best cleaning liquid to give the PCB's a good clean?
DeOxIT from Craig Labs is the normal recommendation. A tiny .14g spray can costs about $8 at the local Radio Shack and one of those will work on a few devices. I don't know where to get it where you live but it's available online, of course.
My normal routine is to burnish the connectors and re-do them with DeOxIT only if that works. One application will last many years.
I hope this works.
