Does DP8 still support Uniwire?
I'm having no luck interfacing a Muse Receptor with DP8 using Uniwire 1.3 on a new Mac Pro running the latest OS Mavericks.
I've never had a problem with this prior to this new machine, a 6 core Mac Pro trash can. I have verified that the Uniwire plug ins are in their components folder in the system library, but they don't show up in DP at all. I even trashed the preference file to rescan all plug ins and it still didn't acknowledge the Uniwire plug ins.
I realize it may be a tiny minority with this particular setup, but any suggestions will be greatly appreciated.
DP8 and Muse Receptor/Uniwire problems
.Bzz...
Mac Pro 6 Core-10.14.6-32GB | DP 10 | 828mkII fw | Receptor 1&2 |Reason 10.2 | Goliath | EWQLSO Gold | QL RA | Voices of Passion | Ocean Way Drums Platinum | SSD-EX | Chris Hein Horns 1&2 | Komplete 12 | AAS - Ultra Analog | BS Accordions | Nomad Factory Integral Bundle | WaveArts Power Suite 5 | Izotope Music Production 3 | Variax 600| TD-8 Drums ||STUDIO››|| MacPro QuadCore-2.66-10.4.11-8GB | 828mk3 fw | 8Pre fw (X2)| MC Mix (X3) MC Control ||
Re: DP8 and Muse Receptor/Uniwire problems
Do you have the same problem if you start DP 8 in 32bit? Try it and see.
You nailed this one Mike. It DOES work in 32 bit. So I guess this means I now have to go to the Muse Research support page and coerce them, or guilt them into making their products 64 bit compatible?mikehalloran wrote:Do you have the same problem if you start DP 8 in 32bit? Try it and see.
So this leads me to the next question. What has become the standard method for running these 32 bit legacy products in 64 bit mode?
.Bzz...
32 Lives - works great. Visit the website to see which plug-ins are "covered" - Muse's might not be:Buzzy wrote:You nailed this one Mike. It DOES work in 32 bit. So I guess this means I now have to go to the Muse Research support page and coerce them, or guilt them into making their products 64 bit compatible?mikehalloran wrote:Do you have the same problem if you start DP 8 in 32bit? Try it and see.
http://www.soundradix.com
http://www.davepolich.com
I think they have a demo as well? Your particular plug in may not be listed, but only because they haven't tried it yet. And yes, it's high time Muse supported 64-bit.
