DP8 stops. Quits.
- 2leftears
DP8 stops. Quits.
DP8.04, Mac Pro quad core, 10.6. Mixing an 8 track, (3 vx, 3 a gtr, 2 piano), live recording. 1 of 4 in a 24/48 DP session. This is the third piece in this session. After I auto muted the vx trx, I was doing the same to the second vx trk when DP stops during playback then quits. The other two mixes in this session play all the way through without quitting. It's not crashing. It stops during playback then quits. I am operating in 64 bit with an Apogee Ensemble. The vocal tracks were touched up pitch wise and every track was auto muted when out. I copied the session to another disk. Same result. Any clues?
Re: DP8 stops. Quits.
What are your buffer settings and work priority? Apogee products need to see2leftears wrote:DP8.04, Mac Pro quad core, 10.6. Mixing an 8 track, (3 vx, 3 a gtr, 2 piano), live recording. 1 of 4 in a 24/48 DP session. This is the third piece in this session. After I auto muted the vx trx, I was doing the same to the second vx trk when DP stops during playback then quits. The other two mixes in this session play all the way through without quitting. It's not crashing. It stops during playback then quits. I am operating in 64 bit with an Apogee Ensemble. The vocal tracks were touched up pitch wise and every track was auto muted when out. I copied the session to another disk. Same result. Any clues?
a work priority setting of "Low" to function optimally. I wouldn't mix at anything under 512 buffer, either.
I actually experienced a similar problem some years back, and it turned out to be a corrupted audio file, every time I hit a certain spot in the playback, bam, DP would quit. Sadly, the only cure was to delete the audio file and re-record that track. You might have the same thing going on.
http://www.davepolich.com
You might give 10.8 a try...
- 2leftears
I opened a new session and imported the troublesome sequence along with the audio files. It worked all day. This action was what MOTU tech support suggested. Problem solved.
