MTP AVI usb: right chips, still no Windows
- Primary DAW OS: Windows
Argh.
I have the correct software in my USB MIDI Timpiece.
Still, no Windows machines (7, XP sp3) can see it.
What can I do? Nothing has helped, I've combed forums so much that my skin is melting into radioactive goo.
I am fed up. I can't just go drop $700 on new MIDI routers from MOTU, especially after this + endless 828 problems. And I *want* to buy MOTU; for the most part, I like their company and their products... when they aren't causing me huge headaches.
-WIlliam
-WIlliam
Re: MTP AVI usb: right chips, still no Windows
Have you tried calling MOTU tech support?
if i recall correctly, the computer should "see" it even if the ROM is not PC-ready. It just wont work correctly...maybe you just have a bad unit?
i don't think getting a new system will cost you $700, btw, unless you are getting multiples.
James;
Not to put too fine a point on it, but
many many manymanymany times.
Ha, there's a unicorn.
Agent, we should compare terminology.
What constitutes being seen by the computer?
Um... maybe you have a broken MTP AV?
I'm hesitant to make any more suggestions, but... do you have access to a Mac to see if the Mac sees it? You installed the MOTU driver software, etc, I assume? I don't know if those interfaces are recognized without running the MOTU MIDI installer.
