Hi
I'm trying to bus individual MachFive sounds to individual audio tracks. I have MachFive 3 as an instrument insert not stand alone. In MachFive 2 I could assign the output to Sound 1 (A1) to bus 1-2 the A2 to bus 3-4 etc. Since upgrading to MachFive V3 it now reads in the out put list on the MachFive as Main Out, Out 2, Out 3, Out 4 etc. Where as there's no input on DP8 for this...! It was so easy to just bounce down individual sounds to their own tracks before but I'm finind I have to mute everything except the track I want to record and bounce it down then place it on the tracks window!
Any help with how I can set up the bus on MachFive V3 so to record to DP8 will be greatly welcome!
Bussing MachFive v3 to DP8
iMac 3.06Ghz Intel Core Duo 4GB 800MHz DDR2 SDRAM /OSX 10.6
MacBook Pro / OSX 10.6 / DP7.22 / MOTU 896mk3 /
MOTU Traveler mk3 / Presonus Monitor Station
New Audio Spatial One Monitors
Re: Bussing MachFive v3 to DP8
Hi
I'm on DP7. It may be different in DP8.
Assign a MachFive part to Out2. In DP Tracks view, for the audio track you want to record on, select INPUT, New Stereo Bundle, MachFive3-1 3-4. You should hear whatever part is sent to Out2. Out3 goes to 5-6, Out4 to 7-8, etc.
Bowman.
Bowman.
iMac Intel Core i5 3.2ghz - 16gb RAM - OSX 10.10.5 - DP 9.01 - Mach Five 3.2.1 - Ethno Instrument 2.0.3 - Kontakt 5.4.3 - 4pre - 828 original - micro express
