MachFive Three MIDI issues
goosetunes
Post by goosetunes »
For some reason, MachFive3 is not reading pitch bend and modulation MIDI data. It triggers sample sounds properly when notes are played on my keyboard, but when I use my pitch bend or modulation wheels the MIDI data is recorded along with the notes I'm playing in DP8, but it doesn't read the data and therefore doesn't affect the note the way it should.
I have other projects where all MIDI data is recorded and interpreted fine in MachFive3. I've also loaded multiple instances of MachFive3 to test, but cannot make the problem go away in this one project. All my other VIs incorporate MIDI perfectly fine which tells me it's not my controller or MIDI connections.
What am I missing? Is there a simple setting in MachFive3 that someone can point me to in order to "reset" MachFive3's MIDI connection?
I'm out of ideas and the manual isn't of much help, so any guidance would be greatly appreciated!
DP 9.52, MachFive 3, MX4, Kontakt5, Omnisphere, PLAY, 828mk3 Hybrid FW-USB2, 8-Pre, MIDI Express XT, Mid-2012 MacPro 2 x 3.46 GHz 6-Core Intel Xeon, 64 GB RAM, Graphics Radeon RX 580 8192 MB, OSX 10.14.6.
Sianth
Re: MachFive Three MIDI issues
Post by Sianth »
I'm having the same problem, so I'd like to hear about a possible solution too.
Post by Shooshie »
Best bet: call MOTU.
