Hi guys,
I downloaded the demo version of Vienna Ensemble Pro 5 and I'm playing with it. It seems very nice, I can finally run my 32bit plugins in DP8 64 bit!
I don't understand how to set it up in order to use it as an insert in an aux track to run my Altiverb 6. Any suggestion?
Thanks a lot!
VEP as insert
VEP as insert
MacOS 15 Sonoma - DP 11 - Mac Mini 2018 i7 2.3GHz - 64GB RAM
Re: VEP as insert
Perhaps you have solved it. But if you follow in troubles this is my recommendation:
1 Open a 32bit VEPServer app in your host computer. Load an instance (lets go to name it as"reverb") and add your plugin in an audio input track (follow VEP manual instructions) Set in this track INx/x and OUTx/x
https://www.dropbox.com/s/07gnijjtvz8df8q/VEP_1.tiff
2 In DP64b open an instrument track and open a VEP instance. Cick VEP connect button. Look for the instance named "reverb" (must be available into a 32b VEPServer) that you created before. Connect it
https://www.dropbox.com/s/o6h8oigk5ximq0a/VEP_2.tiff
As audio send:
3 Create an Aux Track, use a free bus as audio input; isn't necessary an audio output . Insert a VEP audio input plugin. Select as audio input the same INx/x set in step1.
https://www.dropbox.com/s/vod7jr63n7x526d/VEP_4.tiff
4 Send you audio track to same bus selected in Aux Track
https://www.dropbox.com/s/rl3g2imdkext73l/VEP_3.tiff
As insert:
5 Insert in your audio track a VEP audio plugin as in step3. Remember that your audio signal goes to VEP mixer instance and will come to DP through instrument track created in step2
As audio send:
As insert:
DP 10.11 || iMac 2019 5K ||i9 8core 3.6GHz|| 64 GB RAM|| macOS 11.5.1
RME AiOPro || Softube Console 1 ||
Re: VEP as insert
Great, thank you very much man!
