DP8 memory MAXED at start up
- davinci53
After installing DP8 I am noticing my memory reading is slamming into full red and this before i record a single note. I was crashing at start up of DP8 or getting a warning my memory was running low. I read here on MOTUNATION that it may be Kontakt player (i am at V3) so i deleted Kontakt from my plug in list which stopped the crashes at start up but the memory pinning into the red hasn't changed at all. DP7.24 IS WORKING PERFECT with Kontakt.. I guess if i up dated Kontakt this may do the trick? I only need Kontakt for SSD (which i hardly use ) but I still would like it in my start up template ..Any suggestion are welcome.
DP7.24/DP8 * OS 10.6.8 * MAC-PRO * 2x2.66 Ghz * Dual-Core Intel Xeon* 667 Mhz * 2408mk3 (pci 424) *MIDI Express XT *
2 TB main hard drive*-8GB ram- 800 GB (dedicated working drive)
- Ozone 5- SSD-Addictive Drums-GTR Solo--Auto Tune 7- Harmony Efx -Waves Ren Compressor- Waves CLA, Eddie Kramer, Maserati- Ivory Grand Piano 2- I-Drum-Waves L3 ultra-maximizer-bass & vocal rider-Sylenth-Logic Pro used in background for synths & loops-
Re: DP8 memory MAXED at start up
You might check your pre load buffers in audio preferences.
- daniel.sneed
As already stated on this board, memory is displayed in DP8 32 bit only.
AFAICT, the memory display tells: How much memory is *allowed* to DP8, not how much is *actually used* by DP8.
dAn Shakin' all over!
Falcon, Kontakt, Ozone, RX, Unisum & Michelangelo, LX480, Sparkverb
I also regularly see spikes indicated in 64 bit meters, but not in the OS Activity Monitor. This is not new in DP and I've seen it in earlier versions as well. I just shut off the warning message and ignore the little red lights...
Myself and others on here have just turned it off in preferences. It doesn't seem to reflect what's actually happening in the system.
Mac Pro 2.8 ghz Quad Core, 32gb RAM, DP 8.07, OS X 10.8.5
I use the Activity monitor meters - turned off DP's meters. No issues so far.jamesdunlopmusic wrote:Myself and others on here have just turned it off in preferences. It doesn't seem to reflect what's actually happening in the system.
I think a calibration is in order MOTU for next update?
mvh
- davinci53
Thanks for the input.. So what taking away is
there's no problem with my memory showing
It's spiking on opening a brand new template ?
I've yet to use DP8 in fear is crash androstenedione work.
DP8's working fine here - No crashes.
mvh
mvh
