I went to do a telephone sound on a voice and I know that the MOTU 4 band EQ had a preset for it but I could not find it in the plugs list. Does anyone know where it is along with the 2 band? Not the MW Equalizer.
Thanks!!
Where is the 2 and 4 Band MOTU EQ's in DP7.24
DP11.11, Macbook Pro M1 MAX 64gb RAM 2TB SSD, MacPro Mid 2012 12core 3.47ghz 3GB RAM, Cranborne Audio 500R8 & 500ADAT, 25+ 500 Series Modules, UAD Quad Card, Pro Tools 22.5.0.192, UA Solo 610 Tube MicPre, Eventide Eclipse Effects Processor, 2 Eventide H9 Effects Processors, Lexicon PCM 70, 45+ microphones, Genelec 1029's & 1091 Subwoofer, 1986 Yamaha NS-10's with Bryston 2B Amp, Furman AR-2400 Power Regulator, Neural DSP Quad Cortex Amp/FX Modeler, Fractal FM3 Amp/FX Modeler, etc...
Re: Where is the 2 and 4 Band MOTU EQ's in DP7.24
They're labelled ParaEQ (2-band, 4-band, 8-band) in the list here.
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
- Shooshie
Yeah, they're kind of off to themselves in the list. But are you having trouble finding the plugins or the presets? I think the presets may have not made leap to 64 bit with all intact, but that's not your question, I guess. You can make a quick telephone preset by adding a hi-pass filter at, say, 440 or 880, or whatever sounds right to your ears. You may get even closer by adding a bump at around 6K or 8K with a Q of about an octave.barreltone wrote:They're labelled ParaEQ (2-band, 4-band, 8-band) in the list here.
I'm just guessing (and I don't even have DP open at the moment), but I've never thought it hard to create a telephone or old phonograph EQ. Seems pretty straight ahead unless you want to get an FFT meter after an actual telephone and see exactly what it does to a range of sine waves. I guess that's doable, but the hi-pass filter should get close enough for jazz.
