DP 7.24 and ipad
DP 7.24 and ipad
Hello,
I have an ipad 3 and DP 7.24, motu 2408 mk3, motu express XT. I'm wanting to be able to use the ipad as an external sound source but I can't figure out how to set the MIDI up so I can sequence while hearing the sounds on the ipad.
I've searched but just about every post is about controlling DP with the ipad.
I have the iRig MIDI device and y cable for the audio. Any assistance would be greatly appreciated.
new-knee
new-knee
- dave pine
Re: DP 7.24 and ipad
does the vi you are using in the ipad accept incoming MIDI?
mac pro 2.26 octacore 24gigs of ram/ El Capitan10.11, dp 10, mackie dxb, 3-2408mk3, waves mercury 10, ozone 3&4&5678, sound toys, izotope rx, melodyne editor, uad 2, bluetubes, 22" polkadotted dildo, omnishpere 2, trigger 2 deluxe, addictive drums, komplete 9, e/w ql symphonic orq platinum, ql choirs, ql stormdrum 2, ql gypsy, ql ra, ql goliath, ql pianos, superior drummer 3, ez drummer 2, garritan bigband, amg kickass brass, ztar, wife, dogs, droped my protools rig at the city dump
Dave,
Thank you for your response.
Yes, the app is sampletank and I can connect my synth directly and it works fine. But, when I connect the iPad to the motu express XT I don't know how to set it up in audio/MIDI so DP will see it.
New-knee
New-knee
- dave pine
dp doen't need to see it, it needs to see dp, just send the MIDI out to a MIDI out on the xt, and connect that to the in of the ipad, make sure your MIDI channel is set.
have you done this before with other keyboards?
Dave,
Yes, I have several synths and VI'S and never had any problems setting them up. I have the iPad connected to MIDI out 8 on the express xt going in the iPad and my master keyboard MIDI out is connected to MIDI in one on the xt. I can access all my other units but when I try to select the iPad there is no listing for it. For some reason I have no idea of what to do next, I've developed a total brain fart. There should be something to select like "iRig" or something to let me access whatever vi I have instanseated on the iPad.
Thank you in advance for any additional assistance you can give me.
new-knee
new-knee
- dave pine
disconnect one of your keyboards that work, and hook that up to the ipad in and send MIDI to the ( name) of the disconnected keyboard.... is your ipad playing now?
Dave,
Yep, works fine.
new-knee
Yep, works fine.
new-knee
Dave,
Wow! I feel like a total dummy for not being able to figure this out. I just had to add an instrument in audio MIDI and now it works fine. I'm sorry for the trouble but I really appreciate your help.
Once again, thanks a million.
new-knee
new-knee
- dave pine
so just go into audio MIDI setup and name whichever port on the mtp xt you want to use ipad.... hook it up and done.
I've got it working fine now thanks to you. I was searching so hard for a factory setting I completely forgot to just make one. I was sure it had to be more difficult that it was. Anyway,
it is working now and I can play with this I also bought the CMI emulation for ipad! I just bought the stripped down version to see if I might like it and I'm not sure I'll spring for the full version but it is fun to play with.
Once again, thank you for your assistance.
new-knee
new-knee
