Slate's Virtual Tape Machines (VTM)
Kubi
Re: Slate's Virtual Tape Machines (VTM)
Post by Kubi »
Finally got it - first test drives are nothing short of mind-blowing. Works really well in tandem with VCC. With those two together it's not even the same rig anymore, VTM lifts the overall quality of everything up again by about the same amount as VCC already did (and I wouldn't dream of mixing without VCC anymore...)
Brave new world we live in.
:D
Kubi
Kubilay Uner
http://kubilayuner.com
kgdrum
Post by kgdrum »
Kubi wrote:Finally got it - first test drives are nothing short of mind-blowing. Works really well in tandem with VCC. With those two together it's not even the same rig anymore, VTM lifts the overall quality of everything up again by about the same amount as VCC already did (and I wouldn't dream of mixing without VCC anymore...)
:D
Kubi,
What's the CPU hit with this?
I'm on tapatalk so I don't know you rigs specs,
thanks
KG
Kubi
Post by Kubi »
Only tried it on a small mix so far (8 tracks into a single master) so I couldn't tell you. That worked fine. (2008 2x2.8 8core MacPro)
Good news is you can hear an immediate improvement even if you just use one instance on the master - so even if the CPU hit ends up being fairly substantial this thing is well worth it.
Kubi
Kubilay Uner
kgdrum
Post by kgdrum »
I've trained myself to wait on Slate plugs for a few updates for them to optimize,and put on 1 of their killer sales.
But I'm sure it will be great!
Do you use any of the UAD's I'd love to hear from users of both how they compare,sound wise as well as the CPU hit.
Kubi
Post by Kubi »
Nope no UAD here.
Kubi
Kubilay Uner
cbergm7210
Post by cbergm7210 »
Purchased. Well done.
http://www.rfjmusic.com
zed
Post by zed »
Of course I am interested in this...
But since my 2408 mk3 is showing signs of not lasting much longer, I have decided that a UA Apollo will be my new audio interface, which has UAD plug-in processing built-in. The idea of being able to use a bunch of tape machine instances on my tracks without using any of my computer's resources is very appealing (especially since I have suffered the last 3.25 years with a serious bottleneck issue where DP's handling of plugins is concerned).
A 64-bit DP may make this less of an issue, once more RAM is added... but until I get a real sense of what all that is going to look like and how efficiently my computer is going to handle it, I am inclined to hold out for a UAD tape machine (at least for the present)
That said, I am not mixing down any final tracks right now. If I had an album or some tracks that needed to be finalized I would probably jump on this (and I expect that I will at some point). I will look forward to checking out the free trial once DP8 is released, and after any initial bugs have been ironed out.
cbergm7210
Yes, this thing eats CPU's for lunch. My 2009 2 x 2.66 GHz Quad-Core Intel Xeon can only handle 6 or so instances on a current mix I am finishing. Bummer.
Hopefully a more efficient version will soon be forthcoming.
Dan Worley
Post by Dan Worley »
cbergm7210 wrote:Yes, this thing eats CPU's for lunch. My 2009 2 x 2.66 GHz Quad-Core Intel Xeon can only handle 6 or so instances on a current mix I am finishing. Bummer.
Yeah, it's a CPU killer for sure. Because of that, I've been printing it directly to the soundbites via Audio > Plug-ins. I duplicate the Take, merge, and print the plug-in. That way I can easily go back to the original, if need be, but so far I haven't had the need. Oh, and if you're printing a plug-in to a stereo soundbite from the Audio menu, all the plug-ins will be listed as mono, but they're not, they are stereo. That little display error should be fixed by MOTU.
I'm overjoyed with VTM (and VCC).
I still use MPX and Magnetic, but more as specialty tools, like for softening up a harsh hi-hat or something like that. I really like the flexibility of Magnetic, and when it's set right it can sound great!
DP10.13
cbergm7210
My current mix (and many typically) has 25+ VI tracks, so to print the plug I'd have to run every track to an audio track first. A bit o' work, but I am tempted just to try it.
Dan Worley
I always forget that so many of you guys are running a lot of VI tracks. I record bands, mostly, so it doesn't occur to me. But I'm with you, I'm hoping Fabrice can lower the CPU usage.
DP10.13
mhschmieder
Post by mhschmieder »
I can't find my $50 voucher (I own everything else in the Slate Digital catalogue and thought I'd be eligible). Did these come by email or via logging in, and if the latter, which login site (Slate splits it up with some "educational" site as the usual place to go for downloads).
I'm in the middle of moving and may have lost it (thought I got one and printed it out) but can't find it in my email archives either. Maybe for some reason I never received one (I seem to have to re-register with Slate every time I buy a new product).
Also, even more importantly, was/is there a deadline for the offer? I had to evacuate my apartment for a week, so I am having a very difficult time right now trying to get my papers back in order and to make sure I don't miss any time-sensitive offers that came along.
buzzsmith
Post by buzzsmith »
Copied from a fairly recent email...
Demo the VTM now at http://www.slatedigital.com!
Since we value our loyal customers, please redeem a non expiring $50 voucher here:
http://crossgrade-vtm.drumclassroom.net
Hope that helps.
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Dan Worley
mhschmieder wrote:I can't find my $50 voucher (I own everything else in the Slate Digital catalogue and thought I'd be eligible). Did these come by email or via logging in, and if the latter, which login site (Slate splits it up with some "educational" site as the usual place to go for downloads).
I'm not 100% sure, but I think you'll actually get a better price at Audio Deluxe, even without a voucher. They have a crossgrade sale of $199. I think it works out to being $50 less than if you use a voucher at Slate.
DP10.13
spitfire31
Post by spitfire31 »
Dan Worley wrote: I'm not 100% sure, but I think you'll actually get a better price at Audio Deluxe, even without a voucher. They have a crossgrade sale of $199. I think it works out to being $50 less than if you use a voucher at Slate.
:?: The Slate direct price with the $50 voucher is $199. Audio DeLuxe quote an inflated list price of $399 :shock:, less the $200 crossgrade discount = $199.
Do you mean that A DL would be open to a negotiated price lower than that? They seem to encourage customers to 'make an offer'`.
/Joachim
If it were easy, anybody could do it.
