It is currently Thu May 23, 2013 10:57 pm
Text Size
Cable for Playing Videos using DP and a Mac Pro
Postby xsound » Mon Jun 25, 2012 11:12 am
Greetings,
Is the Firewire port on the Mac Pro the one used for playing videos from DP? or is it the Mini DVI one? What cable should I use? If you have a link or recommendation please let me know.
Thanks in advance
xsound
Re: Cable for Playing Videos using DP and a Mac Pro
Postby MIDI Life Crisis » Mon Jun 25, 2012 1:47 pm
Currently Firewire to a Firewire video device (not direct to a monitor) but in DP 8 that should change. What version of DP are you currently using?
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.3 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
Postby xsound » Tue Jun 26, 2012 8:16 am
Thanks for the reply. I am using 7.2. Is there a cable that does the conversion to DVI?
I need to send video out from DP to a projector.
xsound
Postby MIDI Life Crisis » Tue Jun 26, 2012 8:30 am
Without a video converter that is not currently possible as far as I know. A Canopus box will run about $100. It's not something a special cable can accomplish.
Postby xsound » Tue Jun 26, 2012 8:48 am
Do we know when DP8 is coming out?
What are going to be the advantages of using this boxes once DP8 is out?
xsound
Postby stephentayler » Tue Jun 26, 2012 8:49 am
Currently DP can only output full frame DV (standard definition) video through firewire to either a DV card (Canopus) or through a DV camcorder - if it has a firewire connection. These then connect to a screen or projector through standard video connectors.
You can connect a second screen or projector to your Mac through the usual monitor outputs.... but your video will be in a quicktime window (with it's borders) in DP, which is OK for working to picture, but not so good for display.
However, when DP8 arrives, you will finally be able to present a full frame movie on any screen connected to your mac - through DVI or HDMI..... just set up the projector as a second screen for the Mac.
I do this at the moment with dedicated video playback software synced to DP.... I connect the DVI output on my Mac to the HDMI input on my 50" plasma..... and the Mac recognises it as a second monitor.
But it will be nice when I can do it all in DP!
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Mac Pro 8 Core 2.8Ghz 16Gb RAM, MacBook Pro, 2Gb RAM, OSX 10.8.2, DP 8.01, PT9.06, Logic 9.1.8, MOTU Traveler, Ultralite Mk 3 Hybrid, MC MIx, MOTU VIs, Waves, Izotope Everything, Spectrasonics, SoundToys, Slate, Softube, NI Vintage Compressors, spl Surround Monitor Controller, spl Auditor Headphone amp, Genelec 1031A, 1029 5.1 system, Sontronics Mics, iPad etc..
stephentayler
Return to MOTU Hardware & Mac OSX
Who is online
Users browsing this forum: Bing [Bot] and 0 guests
Who is online
In total there is 1 user online :: 1 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
Login Form
