It is currently Tue May 21, 2013 9:14 pm
Text Size
Latency too high with the MOTU 896mk3 Hybrid
Postby Jnv » Sat Jun 02, 2012 9:04 am
Hello everyone,
I've just bought the MOTU 896mk3 Hybrid, which I use with Windows 7 64bits, through USB. I installed the latest drivers.
I bought it for live purpose, but sadly, on the laptop I use for my live sessions, I have to use a buffer of 256 to get about 10ms latency, which is a bit too much for a live setup.
If I set the buffer to a smaller size, I get regular cracks (about one every minute with 128). You could argue that my laptop is to blame, but I also use a M-Audio FastTrack Ultra 8R on the very same setup, and can without problem use a buffer of 128 for a latency of 4-5 ms, or 8ms with a buffer of 256.
I also add that the laptop is quite powerful (2.2Ghz, CoreI7, 12gg ram) and almost none of the CPU power is used for my tests.
I expected something better from a sound card from MOTU, especially regarding the price.
Is there something I can do about the latency?
Thanks a lot.
Julien.
Jnv
Re: Latency too high with the MOTU 896mk3 Hybrid
Postby torrentg » Sat Jun 02, 2012 11:35 am
Hi,
10 ms is borderline imperceivable. Yes, I know you would say otherwise. If you do a blind test, you would never know the difference between 0 and 10ms.
That being said, update all of your drivers to latest, especially chipset, wireless and network. Most wireless are based on Atheros and if yours is too, update that from here: http://atheros.cz
Equally important, uninstall whatever 3rd party security you have in safe mode with the tool from the manufacturer. Reboot and install MSE to replace it.
Uninstall all 3rd party software that installed their own drivers.
Update motherboard bios to latest. Disable all unnecessary apps from starting with Windows.
Google for Black Viper and tweak your services based on his guide.
torrentg
Postby KarlSutton » Sat Jun 02, 2012 8:19 pm
monitor through cuemix instead?
MPB 17" 2.66 i7/8GB RAM, OSX 10.6.8, DP 7.24, 828 mkII, expressXT, Ethno 1 via Ultimate Soundbank, MX4, MSI, Komplete 7, Ivory, Stylus RMX.
KarlSutton
Postby Jnv » Sun Jun 03, 2012 4:45 am
Thanks a lot for your replies.
Actually, 10ms doesn't really bother me. What I'm concerned about is that the MOTU doesn't seem to handle CPU as much as the M-Audio, and I'm afraid of the *future* consequences.
For example, everything seems ok with a buffer of 192. Now imagine one of my song one day becomes more CPU intensive. I'll have to use a buffer of 256, which gives me a latency of 12/13 ms.
I really would mind if that soundcard was used on my desktop computer, but it is used as the core of our live setup: our drummer hears the click from an output of the MOTU, and all our instruments (guitars, voice, bass, synth...) are all managed by the very same soundcard (we use virtual amp simulators such as PodFarm). And I'm afraid that such latency *will* be noticed, somehow, by our drummer, and us trying to follow him (plus the latency of our instruments).
On the exact same setup, I can have better latencies with my M-Audio using the same buffer size. I blame the drivers for that (on a side note, the sound card has also problem being recognized... One thing I can't tolerate as a live setup!).
Too bad, the hardware seems really good.
Julien.
Jnv
Postby NazRat » Sun Jun 03, 2012 6:01 am
What DAW? If you're monitoring through plugs, I would guess that you'd have the same latency issues regardless of interface. If there are problems with the device being recognized, then other issues may be at work. Did you uninstall the M-Audio drivers - some have had problems with a combination of drivers on a system. There are new drivers available from MOTU also.
DP8.03 PT10.3.5 VEP 5.1 828mk3 ADA8000 MTP-AV
Mac Mini Quad 10.8.2
HP 7430s Quad Win8
NazRat
Postby Jnv » Sun Jun 03, 2012 6:34 am
I'm using R•••••. Indeed there is the latency of the plugs to take in account, but also the latency of the interface according to the size of its buffers. That's this one I try to minimize as much as possible.
As for the MOTU not being recognized : it IS actually always recognized (I can access the Asio panel), but the software using it can't always make it work. I tested with both Renoise and R•••••, which work beautifully with any other audio interface I use.
When such problem happens with the MOTU, I change the latency, make another try and it sometimes works. And I've installed the latest drivers. There is definitely something weird with these ones. I have no problem with the M-Audio on both my desktop and laptop computers.
Jnv
Postby NazRat » Sun Jun 03, 2012 7:57 am
I have only looked at R••••• and never really used it, but if I remember correctly it had a fairly complex way to set up buffers - i.e. DAW buffer independent of interface buffer and such. Maybe try playing with those settings if you haven't already or download another free or evaluation copy of another DAW/audio app to see if you have the same issue.
HP 7430s Quad Win8
NazRat
Return to MOTU Hardware & Windows
Who is online
Users browsing this forum: No registered users and 2 guests
Who is online
In total there are 2 users online :: 0 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
Login Form
