It is currently Sat May 25, 2013 8:09 pm
Text Size
LAConvolver problem with DP7.24
Postby Bygat » Fri May 25, 2012 6:31 am
Hi guys!
yesterday i've decided to use LAconvolver for IR with Lepou amp sim, so i copied the .component file of LA 0.3.2 into Library/Audio/Plug In and started DP.
When i put LA into the inert of the aux tracks i created from the sends of the audio track with Lecto , to load some IR , well it doesn't open itself....i don't know why, i have a Macbook Pro late 2011, OSX 10.7.3 , DP7.24...
What can i do to use this plug in?
Bygat
Re: LAConvolver problem with DP7.24
Postby barreltone » Fri May 25, 2012 11:22 am
First, check the input/output settings of your aux track. I've noticed plugins on inserts of my aux tracks not loading when the track is not set up properly first.
Hope this helps!
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
barreltone
Postby Bygat » Sat May 26, 2012 8:34 am
Well, it tries to open but i can sede only a little blank white square on my Mac monitor...
For my routing: from the sends of the Lepou (with no output) track 2 busses to 2 aux tracks with output my main output..
I'm also trying to have more sends on every track but i ' m not able to manage this task..
Forgive me, i'm newbie!!
Bygat
Postby cuttime » Sat May 26, 2012 11:20 am
Track enabled/disabled?
Traveler DP7.24 Unisyn 10.6.8
Postby Bygat » Sun May 27, 2012 3:34 am
Yes, tracks are enabled.
Bygat
Postby Klaus » Tue May 29, 2012 12:43 pm
I think I mailed Tobias about this...
I then went and used an older version... of 3.
Best
Klaus
Klaus
Postby Klaus » Tue May 29, 2012 9:22 pm
Just checked
I use 0.3.1
Klaus
Klaus
Postby Bygat » Fri Jun 01, 2012 1:14 am
Well, now i will look for 0.3.1 and check if it works...
Meanwhile...thanx for the suggestion!
Bygat
Postby Bygat » Fri Jun 01, 2012 11:40 am
Ok , installed 0.3.1 still did not works...
Bygat
Return to Digital Performer [MacOS]: Troubleshooting/Criticism
Who is online
Users browsing this forum: hrw and 3 guests
Who is online
In total there are 4 users online :: 1 registered, 0 hidden and 3 guests (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
