LAConvolver problem with DP7.24
Hi guys!
yesterday i've decided to use LAconvolver for IR with Lepou amp sim, so i copied the .component file of LA 0.3.2 into Library/Audio/Plug In and started DP.
When i put LA into the inert of the aux tracks i created from the sends of the audio track with Lecto , to load some IR , well it doesn't open itself....i don't know why, i have a Macbook Pro late 2011, OSX 10.7.3 , DP7.24...
What can i do to use this plug in?
Re: LAConvolver problem with DP7.24
First, check the input/output settings of your aux track. I've noticed plugins on inserts of my aux tracks not loading when the track is not set up properly first.
Hope this helps!
Hope this helps!
Mac Pro 8 core Nehalem,OS X 10.6.8, MOTU 896HD, DP 7.24, Finale 2009, MSI, Izotope Trash, Spectron, Ozone 4, Alloy, Rx2
Well, it tries to open but i can sede only a little blank white square on my Mac monitor...
For my routing: from the sends of the Lepou (with no output) track 2 busses to 2 aux tracks with output my main output..
I'm also trying to have more sends on every track but i ' m not able to manage this task..
Forgive me, i'm newbie!!
Track enabled/disabled?
Yes, tracks are enabled.
I think I mailed Tobias about this...
I then went and used an older version... of 3.
Best
Klaus
Best
Klaus
Just checked
I use 0.3.1
Klaus
I use 0.3.1
Klaus
Well, now i will look for 0.3.1 and check if it works...
Meanwhile...thanx for the suggestion!
Ok , installed 0.3.1 still did not works...
