SMPTE/LTC without soundcard
Anyone know if a way to generate SMPTE/LTC on an audio track in DP without using one of the MOTU hardware interfaces? I want to send sync audio over jack to another app, if its possible somehow.
DP itself cannot generate sync. If you have some audible SMPTE you can record as a track that might work but the re-recording process tends to' round the edges' of the code making it unreliable.
If it is an important project you should use a device meant to read, write, and generate code.
Re: SMPTE/LTC without soundcard
round the edges? We used to stripe SMPTE to tape in the old days and it always worked fine.
You're welcome. You obviously know more than I do. <sigh>
For anyone that is interested, I think I found a solution. Reaper appears to have a built in LTC generator, you can add LTC to any track. So I stripped a track with 15 minutes LTC and then imported that WAV into DP. Seems to be working so far...
Oh goody...
I was talking about COPYING SMPTE from a previously recorded tape.
uggggh, may I ask why this forum is editing out the name of the other software I used in conjunction with DP to make this work? R E A P E R
