Board index
MOTUNATION Main Forums
Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Plug in will not let me save preset
by Julia123 » Sat May 12, 2012 12:17 pm
I purchased a 3rd party plug in (UBK--1). I found it's preset folder and everything appears to be normal but for some reason it will not let me save my own presets. It says: Access Denied. Insufficient access privileges for the operation. (-5000)
Does anyone know why this won't let me save my own presets?
Thank you
Thank you
iMac OS X 10.6.8, Dual Core, 3.06 GHz, 12g Ram, DP 8.01, Apogee One
- Julia123
Re: Plug in will not let me save preset
by Dan Worley » Sat May 12, 2012 1:59 pm
Most likely it's just a permissions problem. Go to the Kush Audio folder (Library/Audio/Presets/Kush Audio) and in the Get Info window, unlock it and set its permissions to Read and Write and select "apply to enclosed items" from the little gear looking thingy. That might fix it.
I love that plug-in and it saves presets fine here.
DP8.0 • 10.6.8 • 3Ghz Mac Pro (4-core) 1st Gen. - 2006-2007 • 9GB RAM • ATI Radeon x1900
Dan Worley - Posts: 2004
by Julia123 » Sun May 13, 2012 9:19 am
That was it!! Thanks. Now all I have to do is try to remember this next time I see that error message.
- Julia123
by mikehalloran » Sun May 13, 2012 3:29 pm
Julia123 wrote:That was it!! Thanks. Now all I have to do is try to remember this next time I see that error message.
Normally when you get this, the file was copied from somewhere else. To help find and solve a tech support issue, I am running the same test file on more than one 'puter. Every time I copy it from my iMac to my G4 - or back again via Drop Box, I go through this. Same when I copy a Word .doc instead of emailing it.
Programs installed via an installer shouldn't give you this grief but it sometimes happens.
July 2010 iMac 2.93G i7 Quad-core with OWC eSATA mod, 20G RAM, OS 10.8.3
828mkII FW; MIDI Timepiece AV with Intel upgrade chip
DP 8.01, 7.24 with IK, mda, NI, Stilwell/Schwa, Izotope & Antares plugs, MachV 3.1.4
LogicStudio 9.1.8, Finale 2011Cr.1, Encore 5.0.6 & 4.5.5, DSP Quatro 4, QuickTime Pro 7.6.6
Test machine: G4-733: OS 10.4.11 / OS 9.2; DP 5.13; Encore 4.5.5; other legacy apps
mikehalloran - Posts: 2266
by Julia123 » Mon May 14, 2012 6:32 am
That would make sense. I recall having the problem before with a bunch of files when I first migrated everything from my old computer to this newer one, I didn't make the connection at all. Thanks.
- Julia123
by TnMike » Wed Feb 27, 2013 2:03 pm
I've tried going to "get info" on the MW EQ folder and making sure all is "read and write" and then "apply to enclosed items" but I still get error -43 when trying to save a preset. Is there anything else I should try??
Thanks, Mike
Thanks, Mike
G5 dual 2.7 2.5gb RAM, 2408 mkIII, Ramsa DA-7 digital miixer, UAD-1, MTPAV, BFD drums, Ivory piano, B4, Alesis Masterlink, PodProxt, Ozone 3, Apogee Mini-Me, Mach V, Korg Legacy
- TnMike
by Armageddon » Wed Feb 27, 2013 9:59 pm
I used to have this problem with Ozone 4. My solution was a bit more complex (and, as I can see from this thread, probably unnecessary!): I would jot down the parameters of the plug I had set up in DP, close DP, open Wave Editor, open an instance of Ozone 4, replicate those parameters and save it from there as preset with no problem. Of course, in the case of Ozone 4, it was likely that I was using the MAS version in DP and having issues based on that; the AU version I'd loaded in Wave Editor didn't seem to have that glitch.
2008 Black MacBook Core 2 Duo 2.4 GHz/4 GB RAM/500 GB-7200 rpm internal drive • OS X 10.6.8 • DP 7.24 • Wave Editor 1.5.6 • TC Konnekt 24D • Korg K61 • Armageddon Music/Love's Young Nightmare on Myspace • My DP Projects on last.fm • IMDb Page • Facebook
- Armageddon
by TnMike » Wed Feb 27, 2013 10:10 pm
So I should get an AU version of MW EQ and see if that will work? Not sure where to find that.?
G5 2.7 GHZ, DP 7.24, MOTU 2408, Ivory, SD2, B4ll, UAD-1, Melodyne, Ramza DA-7,
- TnMike
by Armageddon » Wed Feb 27, 2013 10:16 pm
TnMike wrote:So I should get an AU version of MW EQ and see if that will work? Not sure where to find that.?
Not sure if that's necessarily your problem, in this case, but: http://www.motu.com/products/software/mwc
- Armageddon
by corbo-billy » Thu Feb 28, 2013 2:22 am
MasterWorks Collection is only 32 Bits _
MacPro SNOW Leopard 10.6.8. D.P. 8.0.3 & Kontakt5.1 _ Fireface800 Universal UAD-2 Quad_ FilterBank2 Sherman &Gibson Explorer _ MIDI Express XT _ Virus C _ Adrenalinn & Voyager Moog _ UAD1e X 2 _ SpeakerPhone _ PEAK Pro 6.03 _ PolyEvolber Keyboard _
http://img13.imageshack.us/img13/7498/irontop9.png" onclick="window.open(this.href)
corbo-billy - Posts: 588
by Armageddon » Thu Feb 28, 2013 2:35 am
corbo-billy wrote:MasterWorks Collection is only 32 Bits _
Yikes, really? I'm sure there would have to be a 64-bit version in the near future. But like I said, I don't even know if that's the actual problem, it's just the one I experienced. MAS can be a fickle mistress.
- Armageddon
by TnMike » Thu Feb 28, 2013 7:59 am
I have DP 7.24, so my MW eq came with the update from DP 5.
Not sure what to do, maybe tech support call. I hope they don't say to reinstall everything:( if anyone else has any more ideas, I would appreciate it!
Thanks,
Mike
Thanks,
Mike
- TnMike
• Page 1 of 1
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: ghobish, gongbass, NeilBlack and 2 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
