It is currently Tue May 21, 2013 5:35 pm
Text Size
Missing Bend in MachFive 3
Postby seppo59 » Mon May 07, 2012 12:26 pm
I can't find anywhere the part bender range value in MachFive 3. There should be easy way to access that setting. Where???
In M5 2 it's in upper right corner among other performance settings (amount of voices, glide etc).
Please, help!
seppo59
Re: Missing Bend in MachFive 3
Postby hugy » Tue May 08, 2012 1:28 am
seppo59 wrote:I can't find anywhere the part bender range value in MachFive 3. There should be easy way to access that setting. Where???
Please, help!
click the pitch knob in the oscillator section of the edit panel.
You'll see the pitch bend connection in the modulation matrix.
Adjust the depth of this connection.
HTH
hugy
Postby seppo59 » Tue May 08, 2012 4:20 am
Thanks, hugy, this helps a lot.
Now, to get a bit further: Can I unlink bender somehow, so i could get i.e. 2 up and 12 down? Tried to figure out mapping but it's at this point too sophisticated for me :O
seppo59
Postby hugy » Tue May 08, 2012 5:43 am
Yes you can. It's trickier to do though.
What you need to do is to apply a mapper to this connection that will remap the input range of the pitch bend to this uneven output.
Click the mapper icon (the one on the left of the depth knob)
Add a mapper, change the range to [-12; 2]
Right click in the region where the bar are drawn and select
Presets > Ramps > Ramp Up
Close the mapper window.
Change the depth knob to 1 (otherwise it will double the range of the mapper leading to [-24; 4] semitones)
And voila !
hugy
Postby seppo59 » Wed May 09, 2012 2:19 am
Thanks again. Now I'm out of stupid questions; time to play!
seppo59
Return to MachFive
Who is online
Users browsing this forum: No registered users and 2 guests
Who is online
In total there are 2 users online :: 0 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
