MOTUNATION Main Forums
Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
New Compressor - Could be good...?
Re: New Compressor - Could be good...?
by bolla » Mon Apr 16, 2012 6:06 pm
cbergm7210 wrote:This is my go to guy to check prices first. He is fantastic:
Arthur Alexander
arteksound@earthlink.net
Thanks for this,
Bolla
Dual 2.5 G5 VEP Slave
PC i7 920 VEP Slave
PC P4 2.8 Pulsar 1+2 Bidule Slave
UAD Sat Quad, Minimoog MS10 + Analogue outboard + patience
bolla - Posts: 240
by cbergm7210 » Thu Apr 19, 2012 7:48 am
Frodo wrote:It's good if you use it "good".
I think a wise short guy with pointy ears once said that.
http://www.rfjmusic.com"
cbergm7210 - Posts: 1379
by Dan Worley » Mon Apr 23, 2012 1:55 pm
DP 7.21 has crashed a few times when I was moving UBK-1 to a different insert slot. That's the only problem I've experienced with it. But after that, moving some Waves plugs crashed DP, too, so maybe something else is causing it. DP7.21 has been so incredibly stable for me that it's rather shocking to have it crash at all.
Dan Worley - Posts: 2009
by cbergm7210 » Mon Apr 23, 2012 2:09 pm
Dan Worley wrote:The more I use UBK-1 the more I love it. It's definitely a winner.
Me too, Dan-O. I slap it on a track and pretty much like it or dislike it right away. It's cool you can switch between 5 different compressor types that all do completely different things to the track, pick the one you want, then back the mix off to get the desired effect.
by sdfalk » Mon Apr 23, 2012 4:28 pm
HUGE bunch o' AU instruments, with Final Cut ProX, DP, leave on the stove for awhile
A Uad 2 Apollo…mmmmmmm
My OS is The amazingly gratuitous Mountain Lion 10.8
- sdfalk
by Killahurts » Mon Apr 23, 2012 8:49 pm
Cytomic's Glue is also wonderful, SSL 4k buss comp, with a few extras..
- Killahurts
by Julia123 » Wed Apr 25, 2012 6:25 am
- Julia123
by Julia123 » Mon May 07, 2012 8:02 am
- Julia123
by cbergm7210 » Mon May 07, 2012 8:20 am
Julia123 wrote:Not only is it good, it is GREAT!!!! Thanks Cbergm for the the info on purchasing it--- very cool person to deal with!!!!!
You bet. Family helps family, eh?
I am pretty much trying this thing on everything. Very versatile.
by labman » Mon May 07, 2012 10:22 am
So that means it was well worth the licenses.
(And the video manual is superbly done. Everyone should folllow his lead!
- labman
by Dan Worley » Mon May 07, 2012 2:05 pm
labman wrote:our engineer says he is able to just use UBK where he would need two or three tools previously. And work faster.
+1
I feel the same way. Less tools to reach for and the videos were extremely well done. Not vague in the least. Real examples given in real time. I was actually entertained, too.
by toodamnhip » Wed May 09, 2012 2:42 am
OS 10.6.7
DP 7.22, MTP AV, 828 mkII
East West Pianos, East West Goliath, Spectrasonics Omnispere, Stylus RMX, Waves Platinum 8, Drum Core, NI Guitar Rig 2 and 3, Miroslav Philharmonik CE, Antares auto tune 7, entire Nomad Factory tube processor library, Peak Pro 6, Reason 3.05, Izotope Ozone 3-4, Trash and Spectron, Ivory Piano, VI One, and Addictive Drums...Ocean way Drums, various other plugs...
toodamnhip - Posts: 2618
by cbergm7210 » Mon Jul 02, 2012 2:31 pm
by jbyerly1 » Mon Jul 02, 2012 3:35 pm
http://www.HorizonEntertainment-NC.com
by cbergm7210 » Tue Jul 03, 2012 6:22 am
jbyerly1 wrote:Do you find find your self fighting distortion and good settings? I need to go back and read about this plug because I must be doing something wrong. Also do you use it mainly as a in channel plug, 2bus, side chained. Where and what do you find it most useful for.
If you're getting distortion it could be because of the Headroom knob is too far counterclockwise. I think the creator said to have the green light blinking every so often as a starting point and experiment from there. Also I have found that the saturation and density knobs can create unusable distortion on some source material, so if you hear anything disable those and see if it goes away.
I try this thing on pretty much everything except things that I am trying to shape with a compressor, like a snare drum or vocals that need to be surgically reigned in. How he describes it as a "motion" compressor is right on. It breathes life when put on drum subs, acoustic guitar, piano, submixes, whatever. Don't forget to experiment with the sidechain high pass knob.
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: Bing [Bot], wheever and 3 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
