It is currently Fri May 24, 2013 9:55 pm
Text Size
Steven Slate Drums 4 *was* completely useless in DP7
Postby JMVideo » Mon May 07, 2012 12:54 pm
**Update - apparently the latest updates to VEPro 5 and SSD4 have resolved this problem**
I just bought SSD4 Platinum and was dismayed to discover it's such a memory hog, you can't load full kits within DP7 unless it's the ONLY plugin running!
To make matters worse, it currently doesn't work with Vienna Ensemble Pro. Argh! My host Mac running DP7 is a 32-bit quad core so I usually run all my 64-bit plugs through VEPro.
What a disappointment. Does anyone know if these issues are being worked on, or is my only hope an upgrade to a 64-bit host and DP8?
__________________________
Mac Pro 2.6Ghz 12Gig RAM, MacBook Pro i7, DP 7.21, VEPro 5, MIDI ExpressXT, 1296, 424 card, Kurzweil K2000, Yamaha CP300, BFD, Komplete 5, Omnisphere, Trillian, Electr6ity, Dyaudio BM6A MKII's
JMVideo
Re: Steven Slate Drums 4 completely useless in DP7!
Postby James Steele » Mon May 07, 2012 1:31 pm
This topic goes in the Troubleshooting section. Moved. Hopefully you'll get some help. This sounds very unusual.
JamesSteele.com | Dean Guitars | Facebook | Google+ | Twitter
2.66 Quad-Core MacPro (1,1), 7 GB RAM, OS 10.6.8, DP 8.01, MOTU HD192, 24I/O, UAD-2 Duo, Lucid GENx192, HV-3C, Red Type B, Dean guitars, Marshall amps, etc., etc.!
Postby Alfred Zigoma » Mon May 07, 2012 2:08 pm
1.vsl promised to fix it in the nearest update
2.B SSD options you can choose the light version download samples.
Maybe this will help you the first time
MacPro Quad-Core 2.8 GHZ 16GB RAM OSX 10.8.3, MacBook Pro 13" 2.4GHz 8GB RAM OSX 10.8.3
DP 8, PT 10, MOTU UltraLite MK3 Hybrid , SSL MADI AlphaLink MX, PMC Tb 2+, Quested S8r, SSL Alpha VHD Pre, Powercore x8, Powercore Express, UAD Quad, Satellite Duo, MC Mix(х2), MC Control, all Slate, VSL VE Pro, VSL SE, VSL Suite, NI Kontakt, etc...
Alfred Zigoma
Postby hrw » Sun May 13, 2012 8:02 pm
JMVideo wrote:I just bought SSD4 Platinum and was dismayed to discover it's such a memory hog, you can't load full kits within DP7 unless it's the ONLY plugin running!
+1 Same problem. Waste of money.... very disappointing!!!
I would advise anyone against purchasing it at this point to use with DP.
They should've been more explicit about these issues. Hope it works soon.
Computer/s: OSX 10.8.3
MASTER:
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
SLAVE:
2 x 2.66 GHz Mac Pro Dual-Core Intel Xeon w/ 16GB RAM.
DAW:DP8.02
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
hrw
Postby JMVideo » Fri May 18, 2012 12:15 pm
The really frustrating part is that the drums sound freakin' awesome. Apparently the Vienna team is working to fix the problem with VE Pro, but no timeframe has been given for the release of the next update.
JMVideo
Postby Alfred Zigoma » Fri May 18, 2012 11:11 pm
DP7.24, SSD4 1.096 beta, VEPro 5.0.10683 - all works perfectly
Alfred Zigoma
Postby mhschmieder » Sat May 19, 2012 11:52 am
There was an update yesterday but I haven't had a chance to try it yet -- also I think fast turnaround on another update was announced. They're working hard on any remaining problems. I haven't tried mine since it first came out, when it didn't work with DP7 yet.
MacPro Quad-Core Intel Xeon (2.8 GHz, 16 GB), OSX 10.6.8, MOTU DP 7.24, BIAS Peak Pro 7.0.1, DSP-Quattro 4.2.2, iZotope RX 2.1.0, Melodyne 3.2.2.2
RME FireFace UFX, Focusrite OctoPre Mk II, True Precision 8, AEA RPQ, Radial PZ-DI, Radial Reamp JCR
Eugenio Upright, Dingwall Afterburner, Yamaha BB-1025X, 60th Ann P-Bass, Fender Select J-Bass, Reverse Jaguar Bass, Gretsch Jet Baritone
Yamaha WX5, Hammond 44 Melodion, Hammond XK-3c, Minimoog Voyager, DSI Prophet '08, DSI Evolver
mhschmieder
Postby hrw » Mon May 21, 2012 8:26 pm
YES! It's finally working. Just updated VE Pro (5.0.10738) and SSD4 (1.096). At last. We need to change the topic heading now perhaps??
MASTER:
SLAVE:
DAW:DP8.02
VI's/Plug-ins:
million others.
hrw
Re: Steven Slate Drums 4 *was* completely useless in DP7
Postby JMVideo » Mon May 21, 2012 9:56 pm
Excellent! I will download the latest updates and give it a try.
JMVideo
Postby forjam » Sun Dec 09, 2012 8:57 am
I have similar problems with SD4. Low memory messages, not loading crash cymbals or electronic kits. It does open work with Vienna Ensemble Pro 5 outside of Pro Tools , but has the same problem. The problem is duplicated in Pro Tools 10, Logic 9.1 as well as the Vienna Ensemble Pro 5. I have an 8 core Mac Pro 24 gigs ram etc, etc. Like most working producers, I own and use most everything and expect a few hic cups with new tech, but can't wait to get these bugs fixed. The drums do sound amazing.
ForJam Productions http://forjam.com
forjam
Postby daveyboy » Sun Dec 09, 2012 11:30 am
I think version 1.1 of ssd4 will fix everything as it now does disk streaming. In loading gigantic cla kits that weigh in at over 1 gig and they're only taking up around 200 mbs of actual ram.
Dave
www.dbwproductions.com
www.myspace.com/dbwproductions
8 core 2.8 mac pro w/ 10 gigs ram, DP7.24, Logic9.1.8 and PT 10.3, Apogee Symphony, UAD2, tons of plugs and VIs, OSX.8.3, 4 room commercial studio great for producers and composers!
daveyboy
Postby forjam » Sun Dec 09, 2012 11:38 am
I am using version 1.1. As far as streaming goes. these are small files. I stream an entire orchestra with my film template in Vienna Ensemble Pro 5 to Pro Tools 10 or even the same template in Logic 9. There is definitely a problem with memory allocation in my opinion. I also have some samples that won't load. The one's that do load are smoking hot! I will be in touch with them tomorrow to see if we can figure things out.
forjam
Postby kgdrum » Sun Dec 09, 2012 1:03 pm
I'm glad I saw this,I've been thinking of updating SSD3 EX (which I never liked or used)to SSD4 EX with the sale($49 until Tuesday)
I've heard the new SSD4 is much better but hearing this, as a DP8 user that does not use VEP ,I think I'm going to hold off.
So most users find they need to use SSD4 with VEP to get this to work with DP?
2.8 Quad MacPro(2008)24 gig ram,OSX10.83, DP8.02 RME fireface 800,Great River ME-1NV preamp,Rode NTK and AT4033 microphones,NI Komplete5,6,7,8U ,Spectrasonics,Arturia, IK + various "boutique" VI's & plugins etc....UAD2, Vdrums (TD20 expanded) Superior 2 etc..., Focal Twin 6 monitors, Shunyata PowerSnakes and Conditioners,too many hard drives... ESATA
kgdrum
Postby forjam » Sun Dec 09, 2012 1:33 pm
I don't know what happened, but I did get SSD4 to run in VEP Pro 5 outside of Pro Tools 10. I imported cymbals from the individual library to complete a kit. I made these adjustments in SSD settings:
Drumkit Detail: Medium
Resampling Quality: Normal
Memory Guard mode: Off
Disk Streaming: Big
This is an amazing library. I don't know why it started working but will still follow up with Slate tomorrow. Good luck.
forjam
Return to Digital Performer [MacOS]: Troubleshooting/Criticism
Who is online
Users browsing this forum: No registered users and 1 guest
Who is online
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
