Can't import Mach5 2 Performance into Mach5 3
by NealF » Tue Apr 24, 2012 10:09 am
I've just tried to import my older performances into the new Mach5. Says it can't load the program.
Any ideas?
Thanks.
Any ideas?
Thanks.
Single Proc. quad core Mac Pro. 16 gigs ram, 2nd SATA 1 tb drive. Snow Leopard. DP 7 and Apogee Duet.
- NealF
Re: Can't import Mach5 2 Performance into Mach5 3
by NealF » Tue Apr 24, 2012 10:21 am
It also isn't importing exs files.
- NealF
by MIDI Life Crisis » Tue Apr 24, 2012 10:24 am
Isn't there an option to load performances instead of programs or something like that? I use M5-2 performances all the time without a problem - both my own concoctions as well as the MOTU banks.
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.4 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
MIDI Life Crisis - Posts: 18137
by NealF » Tue Apr 24, 2012 11:49 am
I can't even find anything in the manual that says how to load or save a performance.
And when I go through the browser and locate an old performance, it says it can't open it.
Also can't open exs files. Seems like most of the others open with no problem.
- NealF
by MIDI Life Crisis » Tue Apr 24, 2012 11:59 am
I don't think I did anything to convert the files. I'll look at it later today if possible.
by NealF » Tue Apr 24, 2012 12:11 pm
Thanks.
Still screwing with it but no luck.
- NealF
by b-righteous » Tue Apr 24, 2012 12:17 pm
Are the performances using a UFS library that is not installed or on your ilok? Is it using a library that is not in your M53 soundbank path? Have you updated to the latest version of M53?
- b-righteous
by NealF » Tue Apr 24, 2012 1:33 pm
Just upgraded to the latest. No difference.
I'm not sure what you mean about the soundbank path. I've got the Mach5 3 folder on an external drive. Inside that folder I've got another folder I created called Old Mach5 sounds. Inside there are all my old sounds and performances.
They all worked with Mach5 2. Thought all I had to do was find them in the new browser.
- NealF
by b-righteous » Tue Apr 24, 2012 3:02 pm
If they use samples from the old M52 library then you need the UFS files that came with M52 installed as well as a copy of M52 installed and authorized.
- b-righteous
by mikehalloran » Sun May 13, 2012 10:04 am
I am not certain if this affects your issue or not.
Page 72 of the manual makes a reference to loading MachFive 2 sounds. You may have to create a new folder called M5 Folder.
July 2010 iMac 2.93G i7 Quad-core with OWC eSATA mod, 20G RAM, OS 10.8.3
828mkII FW; MIDI Timepiece MTP/AV USB with Intel upgrade chip
DP 8.04, 7.24 with IK, mda, NI, Izotope & Antares plugs, MachV 3.1.4
LogicStudio 9.1.8, Finale 2011Cr.1, Encore 5.0.6 & 4.5.5, DSP Quatro 4, QuickTime Pro 7.6.6
Test machine: G4-733: OS 10.4.11 / OS 9.2; DP 5.13; Encore 4.5.5; other legacy apps
mikehalloran - Posts: 2392
• Page 1 of 1
Who is online
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
