MOTUNATION Main Forums
Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
digital performer and objects oriented sequencers
by fafalio » Sat Mar 03, 2012 6:45 am
i ask you if it is possible in DP to apply an effect in non destructive way (via aux, insert effect) not to the whole track but only to a small fraction of a track.
In software as magix samplitude this is possible with the object oriented editing where i can cut a portion of a track and inside that portion i can insert all the effects i want.
thanks a lot,
Alessandro.
- fafalio
Re: digital performer and objects oriented sequencers
by FMiguelez » Sat Mar 03, 2012 6:50 am
For this you don't put the plug-ins in the mixer's channel. You need a time range selection of a sound bite and then use the plugs from the Audio menu and render them as needed.
Tascam DM-24, Yamaha 01v, MOTU 2408 MK3, MOTU MTP AV USB, all Spectrasonics' stuff,
Vienna Instruments SUPER PACKAGE, Waves Platinum, slaved Macs running VI Pro and VE Pro
“In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth.” ― Richard Feynman
FMiguelez - Posts: 5737
by fafalio » Sat Mar 03, 2012 7:00 am
- fafalio
by FMiguelez » Sat Mar 03, 2012 7:47 am
If you only want a particular part of your audio to have an effect then you could set it in the mixer and bypass it afterwards, or simply print it as decribed above. Or use a send and place the effect in a VI Rack. Or cut you audio and put the portion you want in a different track.
Those are pretty much your options.
Is that not enough? What are you trying to do?
by stubbsonic » Sat Mar 03, 2012 7:48 am
Another approach would be to create multiple empty tracks each with the FX inserts you want, and drag regions out of the track into the tracks with the desired inserts. (I.e., select the region of audio, use COMMAND-Y to split the region, drag to adjacent track).
OR, you could use automation, by putting the FX you want on inserts, and automate the bypass state of each insert.
OR, you could create a bunch of aux tracks, each with various FX paths. Then you could use aux send automation to send any track to these aux track FX paths, without having to duplicate the inserts.
by philbrown » Sat Mar 03, 2012 7:53 am
fafalio wrote:my answer is another, i don t want render, i want apply and effect to an object as it would be an effect in the mixer, so acting without rendering to audio.
Make your selection, hit Command-Y (IIRC - to create a new soundbite) and Shift-drag the resulting soundbite to a new track. Apply your plug-ins to the new track as inserts in the mixer. Think of soundbites as objects in this case.
VI computer: Mac Pro 2x2.66 Dual-Core 4Gb RAM OS10.5.8/Windows XP•PCIe424>2408•Microlite
G4 2x1.25 1.25GB RAM OS9.22/10.4.11/Windows XP•MOTU896
Plugs: UAD•Scuffham•Flux IRCAM•NI Komplete•Waves•Stectrasonics•Arturia•Soundtoys•Nomad factory•Camel Audio•PSP•Stillwell•Cytomic•Schwa•Modartt•Korg•AAS•Five12•GForce•Voxengo
The Oversouls
doctorvague (modular synth videos)
philbrown - Posts: 1277
by stubbsonic » Sat Mar 03, 2012 8:26 am
As I mentioned above, if you create an Aux Track with a set of inserts you like, there are ways you can drag elements (either the track itself, or the inserts) onto the CLIPPINGS window such that they would be available in any other project. That way you can feel like you are building a library. I'm only now starting to work with CLIPPINGS after having avoided it for as long as it existed.
by Bren Gun » Sat Oct 13, 2012 7:56 am
In OE, you non-destructively apply an effect to an object or clip inside a track, on the Object Level not on the Track Level. There's no need to copy anything nor is there need to automate on Track Level, nor a need to take many steps, etcetera. You approach the object, apply non-destructively, done. And you can easily remove it immediately if wanted or change it and so forth, pretty much like you would remove an insert from a track.
(I'm also interested in this. My reason is because I come from Samplitude and am considering a switch. I'm on the forum to honestly see if it's wise to switch to DP8. Maybe there are features in DP8 to better facilitate what I want to do.)
Have a good day, all!
- Bren Gun
by bayswater » Sat Oct 13, 2012 8:16 am
I usually just select the portion of the audio that I want the effect on, and drag it to another track, and apply the effect there. If there are a lot of positions where the effect has to be turned on and off, automating bypass is pretty simple.
No doubt, more region oriented editing options would improve workflow for some users, and this comes up often in the wish lists, especially for MIDI.
Dual 2.0G G5 PCI 2G, DP 7.24, OS 10.5.8, 2408 MKII, UAD-1
bayswater - Posts: 3200
by Bren Gun » Sat Oct 13, 2012 9:01 am
If the question is "how it's done", then the yes has already been given or it is known (or at least should be) and the answer is to be responding to "how it's done".
He's asking about the matter the way in which I described it in my previous post. "Can it be done in this particular way?" Either 'yes' or 'no'. Anything else is irrelevant.
- Bren Gun
by amplidood » Sat Oct 13, 2012 9:04 am
I'd rather have Logic's approach, to be honest.
How do I like to work? Out of my "StudioInABag" of course; SwissGear laptop bag (awesome), MacBook Pro (4,1) 2.4ghz/4gb/500gb/Snow leopard, lots and lots of drives, Mbox2Pro, DP, PT, Logic (hardly touch it), Komplete, Reason, too many plugs and VI's to list, Akai LPK25, Korg nanoPAD, wireless keyboard/mouse, Sennheiser 650HD phones...basically i pull four cables out of the bag, hook to the laptop, and go!
amplidood - Posts: 1425
by Radiogal » Sat Oct 13, 2012 9:28 am
Bren Gun wrote:Respectfully, I don't see how that response is even relevant or useful.
Thing is that we always wanna help people here on Motunation.
If it´s not done in the way it´s asked, than we will give all the other options about how to get the same results.
We´re just being helpful.
All DAWs (and other software) have different ways of doing the same things.
The hardest thing of learning new platforms is to sync your brain into the new softwares´ way of thinking.
Once you get it, it all becomes clear.
That´s my long term experience.
Radiogal - Posts: 1383
by amplidood » Sat Oct 13, 2012 10:17 am
This is not respectful. This is nit-picky and displays a misunderstanding of how user forums work. It doesn't matter if everyone's post follows what you perceive to be the necessary parameters. This is a dangerous method of posturing that will alienate you faster than it will help you.
by kgdrum » Sat Oct 13, 2012 2:24 pm
snarky passive aggressive attitude in every post from this user, this kept me from wanting to answer any of his 2 or 3 participated threads.
As always RadioGal & Andy, your both too kind, lol.
kgdrum - Posts: 3606
by James Steele » Sat Oct 13, 2012 2:45 pm
You're not going to last long around here with that attitude. Trust me. People are trying to help. You might try to appreciate that.
2.66 Quad-Core MacPro (1,1), 7 GB RAM, OS 10.6.8, DP 8.01, MOTU HD192, 24I/O, UAD-2 Duo, Lucid GENx192, HV-3C, Red Type B, Dean guitars, Marshall amps, etc., etc.!
James Steele - Site Administrator
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: No registered users and 6 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
