Convert from AUP?
Convert from AUP?
Hi Folks,
I'm getting some AUP (Audacity Project format) files in next week. I need to edit them and output as an mp3. I'd like to use DP.
I figure I can download Audacity and just use that to edit, or save from Audacity in a format that DP can read.
My question is -- can DP simply read an AUP file? (I'd rather just use DP and not download Audacity.)
Now...I can NOT look this up in my manual because we're moving next week and it's packed. (I'm sure that excuse has been used here before, but it's TRUE! )
Fred
Fred
Mac Mini 2.26GHz Intel Core 2 Duo / 4Gb 1067 MHz DDR3 | OSX 10.5.6 | Lacie mini ext-HD 160GB 2MB Cache 7200rpm | DP 5.11 | Ivory | TruePiano | MOTU MSI | Kontakt | iMic audio i/o | M-Audio Keystation 88es | Stewart PA-100B PowerAmp | Yamaha NS-10M monitors | http://soundcloud.com/fredparoutaud/" onclick="window.open(this.href);return false;
- Radiogal
Re: Convert from AUP?
Nope. Neither DP nor any other DAW but Audacity can read AUP files. You need to merge/export all audio files and import them into DP.
I believe Audacity has no OMF EXPORT. Otherwise you can export the AUP to OMF and import the OMF into DP.
Thanks RG -- that works. I'll probably just end up doing the work in Audacity then.
Stay warm!
Fred
Stay warm!
Fred
- Radiogal
That sucks! Try to merge/export as separate tracks. Really. That's how we all do it. No problems.
Fred,
this (from Sound Forge) might help?
http://audacity.sourceforge.net/help/faq?s=files&i=aup" onclick="window.open(this.href);return false;
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
The only reason I have Audacity installed is so that I can open the occasional AUP files I get sent and export them as .aiff for use in DP.williemyers wrote:Fred,
http://audacity.sourceforge.net/help/faq?s=files&i=aup" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
I sometimes needed it to open a few other file types but Toast and QuickTime 7 Pro do a better job of doing that.
