MOTUNATION Main Forums
Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Dumping a 16 track session into DP. How to slave DP?
by wonder » Mon Feb 13, 2012 11:49 am
Using only 8 tracks at a time obviously with ADAT, is there a way to slave DP to adat or someother timecode so that when I dump the first 8 tracks and then go back to dump the 9-16 tracks, it'll all line up and I don't need to try and manually line all the tracks up?
I'm no master at timecode and master/slave stuff and would like to know if there's a possibility to do all this?
ps, he's on his way NOW ... so ANY help is appreciated! I wanna look like I knew ALL this stuff beforehand!
wonder - Posts: 1015
Re: Dumping a 16 track session into DP. How to slave DP?
by williemyers » Mon Feb 13, 2012 11:54 am
Wonder, I'm also not a Master/Slave xpert, but what will you be connecting the Fostex's LightPipe cable to, to do the transfer? Audio interface? Directly in to the Mac?wonder wrote:...a friend coming over with a Fostex 16 track recorder and he wants to dump via lightpipe into DP for further tracking.
OS 10.8.3, Mac Pro 2.8Ghz 8 core, 16 Gig RAM, 4 x >120G hds, 2 x 25" LCDs
Kurz Midiboard, MOTU MTP AV
~me
- williemyers
by wonder » Mon Feb 13, 2012 11:55 am
I'll be going into my 2408mk3
by williemyers » Mon Feb 13, 2012 12:09 pm
~me
- williemyers
by wonder » Mon Feb 13, 2012 12:22 pm
I"ll look it up. Was just looking for a "quick fix response" to be honest.
by wonder » Mon Feb 13, 2012 1:07 pm
by Shooshie » Mon Feb 13, 2012 1:14 pm
Shooshie - Posts: 15355
by wonder » Mon Feb 13, 2012 1:18 pm
I am hooked up Via ADAT but when I select ADAT from DP's clock source, all i get is noise.
When I select 2408mk3: BANK A OPTICAL then the sound is fine but I can't select SAMPLE ACCURATE SYNC in the Setup Menu.
by williemyers » Mon Feb 13, 2012 2:39 pm
aw, man...my bad. didn't realize you were just lookin' for the quick and easy way.wonder wrote:THE MANUAL??!?!?!?![]()
actually, though, the quick and easy way is spelled out in detail on pg. 1085 of the manual...
~me
- williemyers
by NazRat » Mon Feb 13, 2012 3:05 pm
Mac Mini Quad 10.8.2
HP 7430s Quad Win8
- NazRat
by Shooshie » Mon Feb 13, 2012 3:40 pm
by mikehalloran » Tue Feb 14, 2012 4:23 am
I think you have to make two passes and line them up manually. Fortunately, you can grab 8 tracks at a time when you do this - doesn't take very long.
828mkII FW; MIDI Timepiece AV with Intel upgrade chip
DP 8.01, 7.24 with IK, mda, NI, Stilwell/Schwa, Izotope & Antares plugs, MachV 3.1.4
LogicStudio 9.1.8, Finale 2011Cr.1, Encore 5.0.6 & 4.5.5, DSP Quatro 4, QuickTime Pro 7.6.6
Test machine: G4-733: OS 10.4.11 / OS 9.2; DP 5.13; Encore 4.5.5; other legacy apps
mikehalloran - Posts: 2267
by bayswater » Tue Feb 14, 2012 9:11 am
Or you can find a blank spot somewhere in one of tracks 1-8 that is also blank at the same time in one of tracks 9-16, and record a sharp transient. That can be used to line up the two sets of tracks.
I've used both of these to transfer multiple sets of 8 track tapes from the DA-38 to DP. But usually, there is enough common material in the tracks that you can just listen to them and line them up manually.
Dual 2.0G G5 PCI 2G, DP 7.24, OS 10.5.8, 2408 MKII, UAD-1
bayswater - Posts: 3196
by mikehalloran » Tue Feb 14, 2012 9:57 am
I'll add one thing further: If you do the three-pass method, take the same track from both passes and pan center. They are lined up perfectly when there are no phase anomalies - you will be able to hear those, don't worry.
by AnthonyS » Wed Feb 15, 2012 3:19 am
NazRat wrote:I don't think you're thinking right here - the unit doesn't have an ADAT sync port, right? I don't know of anyway to do what you want using ADAT lightpipe. The best you can do is clock off an ADAT lightpipe port - 8 channels of audio only as far as I know. You'll need to use MIDI - specifically MTC/MMC. Both the DP and VF160 manuals should lay it out - too long to explain. Sample accurate, no, but it'll get you really close.
This is how I used to do transfers. Syncing via MIDI. Make the Fostex the Master, and slave DP, so when you start the 160, DP will start too. Should work fine
Good luck
AnthonyS - Posts: 235
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: No registered users and 0 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
