msi expert mode tips?
Discussion of all things related to the MOTU Symphonic Instrument.
joelmusic
Post by joelmusic »
hey, does anybody have any examples of how you are using the expert mode? i am a bit foggy on how i can use it to cross-fade strings, or whatever - i assume you use it in conjunction with MIDI learn. any tips would be appreciated!
thanks -
joel
vic_france
Post by vic_france »
In the specific example of crossfading, you don't need to use Expert mode.. simply load the two string patches to be crossfaded into two slots, both set to the same MIDI channel, and use Modulation-mode MIDI learn (Alt-right click) on the volume knob of each of the two parts, with one of the two parts set to negative (red circle to the left). On the other hand you'd use Expert mode to key-switch between Arco and Pizzi or Tremolandi, for example.
Mac MDD dual 1GB/1.25GB RAM/160GB internal disc/MOTU PCI-424/2408 MK3/MTP AV
MAC OS X 10.3.8/ Digital Performer 4.52/Cubase SX 3.02
MAC OS 9.2.2/Digital Performer 3.11/ Cubase VST_32/5.2pb
joelmusic
Post by joelmusic »
thanks - i'll try it.
ismael
Post by ismael »
:wink: great tip!!! If you have more of...I'm sure a lot of people will appreciate...
hugy
Post by hugy »
Just for info.
if you hit multiple key switch at the same time, it will activate each part related.
Could be usefull in certain case.
Like for orchestra hit.
Have fun.
