It is currently Sun May 19, 2013 4:50 am
Text Size
MachFive Window won't close
Postby sdfalk » Fri Nov 25, 2011 3:30 pm
Here's an odd problem..
I'm working with MachFive (latest version 3) and everything is ticking along just fine.
I then decide to work on a different session.
Imagine my surprise when the MachFive window just remains were it is.
I then realize the toolbar has disappeared??
I open up a brand new session, instantiate a new instance of MachFive, try to close
window...the toolbar disappears, but MachFive remains open..
Try to minimize the window and the task bar disappears, but not MachFive..weird..
Meanwhile, it runs fine..lol..no other real problems to speak of other then this strange
visual glitch..hmmm
A New quad i7 mac mini and a Retina Macbook Pro 16gb of ram in each a ton of native plugins, and a
HUGE bunch o' AU instruments, with Final Cut ProX, DP, leave on the stove for awhile
A Uad 2 Apollo…mmmmmmm
My OS is The amazingly gratuitous Mountain Lion 10.8
sdfalk
Re: MachFive Window won't close
Postby sdfalk » Tue Nov 29, 2011 3:10 pm
Wow...
So i'm the only one with that problem..weird..
oh well..
sdfalk
Postby Tuxtla » Sat Dec 10, 2011 11:34 am
You're not alone. Same thing happens to me.
With one instance of MachFive open in a V-Rack, if I close that Digital Performer project (7.24) and open another DP project the original MachFive 3 window stays visible but the toolbar is gone.
MacBook Pro 2.8 GHz | 8 GB RAM | Mac OS X 10.6.8
DP 7.23 with MachFive 2, MX 4, | Alchemy | Rapture | AltiVerb 6 | NI Reaktor 5, Kontakt 4, Absynth 5 | PSP Lexicon, 84, 608 and Nitro | Augustus Loop | Spectron | Novation Remote 37SL.
Tuxtla
Postby MIDI Life Crisis » Sat Dec 10, 2011 11:43 am
Have you guys reported this to MOTU?
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.3 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
Postby cbird1057 » Mon Jan 02, 2012 8:24 pm
My experiences with MachFive 3 have been pretty awful. Reminds me of the old releases of Performer back in the late 80's and being on hold for those phone calls to tech support. But that was over 20 years ago, so things have gotten better... except for MachFive it would seem.
Yup, the window doesn't close. Hmmm, can't move the window either. Oh... what happened to the little bar on the top? Gee, I guess I should check another VI to see if the same thing happened... CRASH!
OK, rebooted. I'll just load a sound into MachFive 3. Nothing too big, just a few little samples in the instrument, it should be fine. I used the instrument in MachFive 2 so I know it works. There, found it, I'll just load it up. Uh-oh, this is taking a little longer to load than I expected... CRASH!
OK, rebooted. Um, maybe I'm doing something wrong using it as a VI in DP. I'll use it as a standalone with Rewire. Right, just patch it in and it will be fine. Oh... DP can't find it. Hmm, there it is. I could have sworn MachFive 3 didn't show up a minute ago. Now I can simply select it and... CRASH!
Forget about migrating MachFive 2 performances. Guess what... CRASH!
It's a good thing I have another sampling VI otherwise I would get nothing done at all. Does anyone else around here feel like they got whacked in the nuts?
:deadhorse:
Mac OS 10.7.2 8GB RAM Core Audio
All the other VI's work fine, even SampleTank (ouch!)
Two 27" iMacs, (1) 3.06 GHz Core 2 Duo with 16GB RAM running DP7.24 + VE Pro 5.1.1 64-bit Server, (1) 3.4 GHz Core i7 with 32GB RAM running VE Pro 5.1.1 64-bit Server, OS X 10.7.5. VIs include MachFive, LASS, Albion, EWQL, Miroslav, SAM, Orchestral Tools, and others too shameful to mention.
cbird1057
Postby MIDI Life Crisis » Mon Jan 02, 2012 8:37 pm
It would seem your experience is not typical. Not sure why. M5-3 works flawlessly on both my G5 and Mac Pro. I'd call MOTU as early as possible tomorrow.
Postby sdfalk » Mon Jan 02, 2012 8:50 pm
MIDI Life Crisis wrote:Have you guys reported this to MOTU?
Yes I did...the day after it happened..
No one ever got back to me ..
BUT..I dumped the prefs, recently updated, and (for now) the
problem seems to be gone.
This doesn't excuse the fact that they should have gotten back
to me at some point..
sdfalk
Postby MIDI Life Crisis » Mon Jan 02, 2012 9:07 pm
Yeah. I don't do tech links 'crept fur an exercise in futility. I get my best answers right cheer but even when I do get thru to the phone line it's hit or miss depending on who answers. Very frustrating when you're up to your ass in crockergators.
Postby cuttime » Mon Jan 02, 2012 9:22 pm
I don't use MachFive, but for unclosable windows a quick fix is often to change the screen resolution to a different setting and then back. This can reveal a missing tool bar.
http://reviews.cnet.com/8301-13727_7-57 ... =txt;title
Traveler DP7.24 Unisyn 10.6.8
Postby MIDI Life Crisis » Mon Jan 02, 2012 9:26 pm
Good tip. Thanks Cuttime.
Postby cbird1057 » Thu Feb 09, 2012 8:57 am
Well, finally got MachFive 3 to behave itself. I updated to the 3.0.2 version but it didn't help much, although I was able to load single performances without it crashing so there was a glimmer of hope.
I ended up checking the crash reports and one thing that kept coming up was references to MachFive 2 components. I went through the whole computer and trashed all the MachFive 2 stuff that had been installed in hidden folders and system locations. I had already "uninstalled" MachFive 2 but I guess that wasn't enough.
MachFive 3 is working now with no crashes. The only thing that still happens is the window remaining open after I close the application, which was the whole point of this thread? Oh well.
cbird1057
Postby FMiguelez » Thu Feb 09, 2012 9:25 am
cbird1057 wrote:My experiences with MachFive 3 have been pretty awful. Reminds me of the old releases of Performer back in the late 80's and being on hold for those phone calls to tech support. But that was over 20 years ago, so things have gotten better... except for MachFive it would seem.
I've been using MachFive for the past few weeks and it works flawlessly for me.
I actually LOVE this sampler to the point I don't know how I've managed before without it.
cbird1057 wrote:Well, finally got MachFive 3 to behave itself. I updated to the 3.0.2 version but it didn't help much, although I was able to load single performances without it crashing so there was a glimmer of hope.
There you go... at least you had some important and positive progress.
Now, that non-closing window is very weird. It hasn't happened to me.
The fact that it happens to some people only suggests it is not directly related to MachFive 3 per se, but some interaction of it with something else (software or hardware).
What do the MOTU tech-support guys suggest for you?
Mac G5 dual 2GHz/4 GB RAM / OSX 10.5.8 / DP 7.24
Tascam DM-24, Yamaha 01v, MOTU 2408 MK3, MOTU MTP AV USB, all Spectrasonics' stuff,
Vienna Instruments SUPER PACKAGE, Waves Platinum, slaved Macs running VI Pro and VE Pro
“In physics the truth is rarely perfectly clear, and that is certainly universally the case in human affairs. Hence, what is not surrounded by uncertainty cannot be the truth.” ― Richard Feynman
FMiguelez
Postby carltonrice » Sun Mar 18, 2012 8:20 am
I just noticed a new version of M5 (v3.0.3) was posted earlier this month and was hoping it would solve this issue, but it didn't. It's been this way ever since release of M5 v3. I can't seem to find any particular pattern to when it will close the M5 window properly with the closing of a project. Sometimes it closes out M5, sometimes not. Not a major issue. It just forces you to quit DP and then re-open it. I've had a few crashes, but overall, I am very happy with M5 v3. Particularly with the samples.
carltonrice
Postby cbird1057 » Sun Mar 18, 2012 9:40 am
Indeed, the 3.0.3 update didn't fix the persistent window problem. I was on the phone with MOTU earlier this week trying to fix something in DP, unable to view some files after I quit the program because of that MachFive window and had to reboot. Sort of embarrassing, actually.
cbird1057
Return to MachFive
Who is online
Users browsing this forum: No registered users and 2 guests
Who is online
In total there are 2 users online :: 0 registered, 0 hidden and 2 guests (based on users active over the past 5 minutes)
Login Form
