Altiverb
- croyal
Isn't vs4 of Altiverb VST-RTAS only? You may need to upgrade to vs 5 to get AU functionality.
However, the wrapper "should" work. Contact the developer to see if Altiverb4 is on the list of supported apps. Meanwhile check your Library-Audio-Plugins-VST folder for the Altiverb VST plug and the MAS folder for the wrapper plug to see if installed correctly. You may need to install both again if still having trouble.
Chris
Chris
Mac Studio Ultra/ 2013 Trashcan. DP10 and 11.
32 channels of Apogee Symphony MkII/ Dangerous 2Bus+.
Lots of Neve, API, and Dangerous outboard gear.
- sdfalk
It's never been just VST Rtas onlycroyal wrote:Isn't vs4 of Altiverb VST-RTAS only? You may need to upgrade to vs 5 to get AU functionality.
Chris
Pretty Hilarious..
Contact the developer of the VST wrapper (who happens to be the developer of Altiverb)
A Metric Halo ULN8-3D…mmmmmmm
There's no reason to use a VST wrapped version, unless its cracked, in which case you're a criminal. AudioEase tells users to use only the MAS version with DP, not AU. If you purchased the program, like scrupulous, civilized human beings do, it should include MAS, AU and VST versions. Just install the MAS version. Simple. If you're a crook, just looking to scam Audioease and all of us, may your computer and HD crash, and you lose every project and software you've ever created or purchased.
