It is currently Mon May 20, 2013 9:02 pm
Text Size
DP: Varispeed Pitch Shifting
This forum is being developed and is intended as intended as a place to bring together various Digital Performer video tutorials. Currently only YouTube videos may be embedded using the [YouTube] BB code.
Postby Umbrella » Fri Dec 31, 2010 8:02 pm
This is one way to achieve varispeed-esque pitch shifting in DP. Using this method, shifting -up- or -down- above a soundbite's base pitch (encoded sample rate) yields better results than shifting below the soundbite's base pitch.
iMac C2D 2.16 2.5 gigs ram - 10.6.8 - DP 7.24 - Logic Pro (9.15) - TC Electronic StudioKonnekt 48 - Novation X-Station 49
Umbrella
Re: DP: Varispeed Pitch Shifting
Postby mkoplin » Mon Nov 14, 2011 9:28 am
audio is not working properly for me.
MacBook Pro, Intel Core 2 Duo, 2.4 GHz, 4GB
Mac Pro, Quad-Core Intel Xeon, 2.8 GHz. 2 Processors, 8 Core, 6 GB
Digital Performer 7.2, M-Audio Axiom 25, Yamaha CVP 305
mkoplin
Postby Umbrella » Mon Nov 14, 2011 4:14 pm
You may have to let it run a bit... :wink:
Umbrella
Postby macguy » Mon Nov 14, 2011 9:29 pm
What's varispeed?
Never heard of it.
macguy
Postby dix » Tue Nov 15, 2011 2:27 am
What is this video suppose to be showing us? I can't make any sense out of it. Perhaps the audio isn't playing correctly?
3ghz 8-core (2008), 10.6.8, 12GB RAM, NVIDIA GeForce 7300 GT, DP (latest version), 2408mk3, Apogee Ensemble, UAD-1(x2) ::: 15-inch MBP (early 2011) 10.6.8, 4GB, Mbox2 Mini
dix
Postby stephentayler » Tue Nov 15, 2011 3:58 am
It's actually showing how to do a pitch bend, like using a pitch wheel, on audio. Actually nothing to do with varispeed (which is all about changing the pitch AND time, like using a speed control on a tape machine)
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Mac Pro 8 Core 2.8Ghz 16Gb RAM, MacBook Pro, 2Gb RAM, OSX 10.8.2, DP 8.01, PT9.06, Logic 9.1.8, MOTU Traveler, Ultralite Mk 3 Hybrid, MC MIx, MOTU VIs, Waves, Izotope Everything, Spectrasonics, SoundToys, Slate, Softube, NI Vintage Compressors, spl Surround Monitor Controller, spl Auditor Headphone amp, Genelec 1031A, 1029 5.1 system, Sontronics Mics, iPad etc..
stephentayler
Postby Umbrella » Tue Nov 15, 2011 5:28 am
stephentayler wrote:It's actually showing how to do a pitch bend, like using a pitch wheel, on audio. Actually nothing to do with varispeed (which is all about changing the pitch AND time, like using a speed control on a tape machine)
Cheers
Stephen
Using a pitch wheel has "nothing to do with varispeed"? Erm... Have you ever played with the pitch wheel on a traditional sampler? The pitch and time change as you move the wheel. Doing so amounts to the digital equivalent of tape varispeed.
"Standard Pitch Shift" mode for soundbites puts DP's pitch automation into control of the pitch and duration of the digital audio. It is not a true emulation of tape varispeed, however, because in going below the soundbite's encoded sampling rate, DP's algorithm forces what would be a longer soundbite into truncated pieces; hence, the note about going above the encoded sampling rate yielding better results.
Umbrella
Postby macguy » Tue Nov 15, 2011 8:29 am
As I listen I can say I don't want to ever use varispeed in my productions...
I never even heard of the effect... I must be in the dark ages.
I know about changing the speed of the capstan on an analog machine, but never had the urge to go do that during a production... my band mates would whoop my rear end!!! Different strokes for different folks I guess.
macguy
Postby Dwetmaster » Tue Nov 15, 2011 11:12 am
I think the idea is a good alternative if the chipmunk effect is desired. Maybe Umbrella could have chosen a different sample to do his video with. So that we could've seen (and heard) the effect of varispeed a bit more. And in a less speaker blowing way... :)
Thanks Umbrella!!!
MacPro 8Core 2.8GHZ 16GB RAM OSX10.6.8
MacBook Pro 17" Unibody 2011 OSX10.7.4
MacPro Nehalem QUAD 2.66GHZ 6GB RAM OSX 10.6.8
DP7.24-DP8.01, Bidule, M5 3, Ethno 2, BPM 1.5 Kontakt4, BFD2, SD2, Omnisphere, Wave Arts P-S5, Altiverb7, PSP VW & OldTimer, VB3, Ivory 2 Grand, True Pianos, Ozone 4, Reason 4, AmpliTube3, Bla bla bla...
A few El & Ac basses, Variax300, Hammond A-100.
Dwetmaster
Postby dix » Tue Nov 15, 2011 1:14 pm
macguy wrote:As I listen I can say I don't want to ever use varispeed in my productions...
I agree. Based on this example vari-speed seems not at all useful. No offense Umbrella. Thank you for taking the time to create this video and posting, but it's not a demo of vari-speed exactly. It just sounds and looks like you're modifying pitch automation. Does that program sound different without Standard Pitch Shift?
At the risk of re-heating a common topic, until the digital era vari-speed usage was common. Debatably as common as delay, eq and compression. Nearly every Beatles recording from Rubber Soul on employed vari-speed at some point in the process. Listen to Strawberry Fields Forever for a veritable showcase of what this technique is capable of.
More than you could possibly want to read on the subject: viewtopic.php?f=26&t=42365&hilit=vari+speed
dix
Postby Umbrella » Tue Nov 15, 2011 6:07 pm
You guys are a riot! :rofl:
Umbrella
Postby jjhp3 » Tue Nov 15, 2011 6:11 pm
I think varispeed is indeed useful; but I use SoundHack for the real deal. Don't make fun of music that's not your style... all tools are useful to someone and I appreciate Umbrella giving it a shot for us all!
John
MP8 x 2.66GHz / DP7.22 / OS X10.8.2 + UltraLiteMkIII
jjhp3
Postby dpg4macman » Sun Jul 15, 2012 6:55 pm
Thanks Um,
Appreciated - mvh
Mac Mini 2.5GHz i5,OSX 10.8.2,16G ram,DP 8.0.2, S1v2, Mixbus, MachFive 3, MX4, IK Total Workstation 2 Bundle, T-RackS 3 Deluxe, Wave Arts Power Suite 4, Gigs & Gigs of samples, EZ drummer, BFD ECO, Stephen Slate Drums, List goes on..., Kurzweil K2000s, TrapKat, Washburn Idol & G5V Guitars, Ibanez Bass, Vox-ToneLab LE, Epiphone Valve Jr., Mackie 1202, Symetrix 525, Alesis 3630, Axiom 49, Audix_Cad 300e_AT 4033 mics, KRK Rokit 5 monitors, Etc...
dpg4macman
Postby zed » Tue Jul 17, 2012 12:27 pm
As already mentioned above, the Beatles used varispeed in a lot of songs by indeed varying the speed on the tape machine. It was a good stroke for those folks, and for the generations who have loved the songs they created employing this technique and variations of it.
So you really must be in the dark ages... (i.e. the era before multi-track recording.) ;-)
MacPro 2.8 GHz 8-Core Intel Xeon | 14 GB RAM | OS 10.6.2 | DP 7.12 | MOTU 2408 mk3 | Mytek Digital ADC | MIDIsport 4x4
zed
Return to Digital Performer: Tutorial Videos
Who is online
Users browsing this forum: No registered users and 0 guests
Who is online
In total there are 0 users online :: 0 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
Login Form
