The OFFICIAL DP7 Bitching and Moaning Topic
Re: The OFFICIAL DP7 Bitching and Moaning Topic
by EMRR » Sun May 01, 2011 8:01 am
Just moved to DP7 from DP6. Am I crazy to want a shortcut button added to the tuner plug, to toggle Input Monitoring Mode? That might actually make it useful in my implementation.
Doug Williams
Tape Op issue 73
DP 7.22.
PPC G5 Dual 2.0, 6GB RAM, OS X.4.11 and X.5.8 dual boot (only X.4.11 works correctly with DP!), MOTU 2408mk3 & 24I/O.
2.4GHz Intel MBP, 4GB RAM, OS X.6.8, used mainly for editing and pre-mixing when out of studio.
AlphaTrack controller.
Several tons of analog gear, DP generally used like a tape machine with editing capabilities, some processing plugs per track, exporting multitrack to analog world.
Tape Op issue 73
DP 7.22.
by kassonica » Mon Jul 04, 2011 4:34 am
Well I'm going to bitch and moan about the fact that there is nothing to bitch and moan about in DP7.23......
http://www.myspace.com/skippysbrain
kassonica - Posts: 5093
by Shooshie » Sun Oct 30, 2011 9:45 am
kassonica wrote:Well I'm going to bitch and moan about the fact that there is nothing to bitch and moan about in DP7.23......
What are they trying to do? Put this lucrative forum out of business? What are we going to do with all our extra time? USE these apps? Curse you, MOTU! You're trying to destroy us!
[with tongue in cheek, of course
]Shoosh
|l| OS X 10.8.3 Mountain Lion |l| DP 8.03 |l| 2.4 GHz 12-Core MacPro 2012 |l| 12GB RAM |l| Mach5.3 |l| Logic Pro 8 |l| Waves 9.x |l| Nomad Factory Vintage Plugins 1.4 |l| Altiverb |l| Ivory 2 |l| Wallander WIVI 2.30 Winds, Brass, Saxes |l| Garritan Aria |l| VSL 4.1.8 |l| Yamaha WX-5 MIDI Wind Controller |l| Roland FC-300 |l|
Shooshie - Posts: 15491
by Crashdown » Mon Nov 07, 2011 10:20 am
Hi Guys,
I'm still a bit angry about DP. when it comes to editing audio... why does the GUI slow down so much when you zoom in at a Soundbite? It just lag's and lag's....
Does DP7.24 not use all the graphic resources available on my MacPro Quad 2.66 intel Xeon?
How can I make this better? Adding RAM? Buying a better Graphic Card?
Help... I'm tired of infinite editing hours... (My wife too, BTW...)
THanks,
Toni
THanks,
Toni
- Crashdown
by Phil O » Mon Nov 07, 2011 10:30 am
Perhaps it's something in your setup. I'm not seeing that problem, even with heavy track counts. If this is becoming a problem for you, it's time to do some detective work. I'd start with studio settings, take a look at memory and CPU usage with Activity Monitor, and then dig into your VI's and plugins. Perhaps others will chime in with suggestions as well.Crashdown wrote:... why does the GUI slow down so much when you zoom in at a Soundbite? It just lag's and lag's...
DP 7.24, Mac Pro 2.66 quad (6 Gig RAM), Mac Pro 2.8 octo, (12 Gig RAM), OS 10.6.8/10.8.4, two MOTU 828s, Apogee Rosetta 800, UAD-1e, UAD-2, a whole truckload of outboard gear and plug-ins, and a partridge in a pear tree.
Phil O - Posts: 4844
by Crashdown » Mon Nov 07, 2011 12:30 pm
Thank you Phil!
Maybe this has to do with the System:
OSX 10.6.8 SnowLeopard
2 x 2.66 GHz Dual-Core Intel Xeon
5 GB 667 MHz DDR2 FB-DIMM
GFORCE 7300 256MB
SSL MADIXTREME 64
SSL ALPHA LINK
U Think it's time to move to a better CPU? Think More RAM will help? Anyone?
I'm really annoyed by those graphic lag's, with CPU Spikes on the performance meter...
Cheers,
Toni
GFORCE 7300 256MB
SSL MADIXTREME 64
SSL ALPHA LINK
Cheers,
Toni
- Crashdown
by Phil O » Tue Nov 08, 2011 8:28 am
I'm running the same machine as you with only 1 more Gig of RAM and the same OS. It runs DP just fine. Are you running a lot of VIs or is it mostly audio? I use very little in the VI department. Perhaps that's where you're getting the CPU hit. Buffer settings? Work Quanta, Prime Seconds, Max Work Percent?
My settings:
Work Quanta: 80
Prime Seconds: 3.00
Max Work Percent: 99%
Buffer 1024
My settings:
Work Quanta: 80
Prime Seconds: 3.00
Buffer 1024
by Crashdown » Tue Nov 08, 2011 9:07 am
Hi Phil,
thanks again for your concern...
I'm not using any VI's...! On a 40 audio track with 12 subgroups, it just lags when I'm editing audio and zooming in on the sequence editor window...
settings:
Stereo Busses 32
prime sec: 2.50
Work Quanta: 100ms
Max work Percent: 95%
Automatic Plug Latency checked
Pre-fill Buffers checked 0.40 seconds
Pretty much the standart settings... gonna try out your settings and report back.
Cheers,
Toni
settings:
Stereo Busses 32
prime sec: 2.50
Work Quanta: 100ms
Cheers,
Toni
- Crashdown
by toodamnhip » Tue Nov 08, 2011 11:47 am
Shooshie wrote:In my experience, the bugs and crashes that are genuinely a MOTU problem will eventually show up on my system. Pretty much all such problems people have complained about in the past eventually happened while I was using whatever was the current version of DP at the time. Sometimes they happened only once or twice. Other times they happened so often I couldn't get anything done. But those things which were more circumstantial -- something caused by the combination of DP with certain plugins, MIDI drivers, audio drivers, permissions, OSX issues, or whatever -- usually did not happen to me. In some cases they did happen, I was able to locate and fix the conflict, and then they never happened again.
I can't say that DP7 has no bugs or doesn't inherently crash; I can only say that since installing Snow Leopard, with DP 6.02 and DP7, I've had DP open sometimes for days at a time, and almost always open during the day, with a variety of projects ranging from a single piano VI to well over a dozen VIs, often experimenting with new plugins and presets, and so far I have not had a single crash or quit. I realize that many people ARE having massive problems, but I think in the end we will find that this is a circumstantial problem. There have been some probable causes identified, but so far nothing that works for everyone. Apple has acknowledged some problems that it's working on, too. It'll just take time.
My sympathy goes out to those who are having problems but can't find the cause. I know it's frustrating.
You always seem to run so clean and well.
I have to wonder, how much audio do you run?
When I have crashes with VI's and such, I have large amounts of tracks with tons of automation, lots of sub bussing etc..
When you mentioned in your nice report of keeping your system running for days without a crash, it sounds like you're mainly running MIDI and VI.s
If so, I wonder how you'd run with the kind of intensive audio, routing, plug in automation etc...that I and possibly others use?
2 x 2.4 GHz Quad-Core Intel Xeon-8GS 1066 MHz DDR3 Mac
OS 10.6.7
DP 7.22, MTP AV, 828 mkII
East West Pianos, East West Goliath, Spectrasonics Omnispere, Stylus RMX, Waves Platinum 8, Drum Core, NI Guitar Rig 2 and 3, Miroslav Philharmonik CE, Antares auto tune 7, entire Nomad Factory tube processor library, Peak Pro 6, Reason 3.05, Izotope Ozone 3-4, Trash and Spectron, Ivory Piano, VI One, and Addictive Drums...Ocean way Drums, various other plugs...
OS 10.6.7
toodamnhip - Posts: 2646
by Alfred Zigoma » Wed Nov 09, 2011 12:49 pm
Crashdown wrote: why does the GUI slow down so much when you zoom in at a Soundbite?
I have the same configuration of a computer and the same problems , seems to me it from - for capacities of a videocard, it is interesting to me why DP is not optimized under old computers . I leave
From position by hot keys and hiding those tracks above which I do not edit at present , I Think to make a upgrade of a videocard or to buy a new Mac Pro
MacPro Quad-Core 2.8 GHZ 16GB RAM OSX 10.8.3, MacBook Pro 13" 2.4GHz 8GB RAM OSX 10.8.3
DP 8, PT 10, MOTU UltraLite MK3 Hybrid , SSL MADI AlphaLink MX, PMC Tb 2+, Quested S8r, SSL Alpha VHD Pre, Powercore x8, Powercore Express, UAD Quad, Satellite Duo, MC Mix(х2), MC Control, all Slate, VSL VE Pro, VSL SE, VSL Suite, NI Kontakt, etc...
Alfred Zigoma - Posts: 45
by BobK » Wed Nov 09, 2011 1:06 pm
If I were you, I'd get more RAM and see if that helps.
Bob
Mac Pro 8-core 2.26 GHz ('Nehalem'), 16 GB RAM, OS 10.8.3 || DP 8.04 || Metric Halo ULN-8 and 2882-2d+DSP
BobK - Posts: 1207
Input Quantize Should Be a Preference
by KenNickels » Fri Jan 20, 2012 5:06 pm
Why do I have to enable it every freaking time? I always forget.
Mac Pro 1,3/3Ghz, 8 core, 8GB Ram, OS 10.6.8, MOTU Audio Express, DP 8.01, Machfive|3, Eastwest Sample Libraries
KenNickels - Posts: 202
Return to MOTU Theoretical Discussions, Gripes, Petitions & Off Topic
Who is online
Users browsing this forum: No registered users and 0 guests
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
