Problem Registering DP 4.6 on Tiger
Hi,
does any one know why DP 4.5 (or its 4.6 upgrade) don't accept my VALID serial number to run? I just moved my system from minimac/panther to G5/Tiger and I can't install the software.
Thanks in advance
Mariano
Thanks in advance
Mariano
Look for this invisible file on the destination disk for the attempted install -- "Auth-DigitalPerformer 4.5". If it is present, you will need to delete it. Use this utility, http://www.tice.de/m4e/a_software/downl ... bles_e.sit, to turn all invisible items into visible, make sure to change them back when you are done.
