It is currently Fri May 24, 2013 5:57 pm
Text Size
TUTORIAL: M-Audio Axiom/Oxygen Transport Controls with DP
Re: TUTORIAL: M-Audio Axiom/Oxygen Transport Controls with DP
Postby dhm » Mon Oct 19, 2009 3:46 pm
Thank you all for adding your help and advise with M-Audio keys. I have a Keystation Pro 88 is there a different setup I presume to control the transport in DP 6.02 and I guess DP 7 also. I notice there's no Loop button etc. but the software Enigma is the same. Any advice would be great! Thanks Don H
dhm
Postby matthis » Tue Oct 27, 2009 7:15 am
There seems to be a simple solution for the stuck stop button problem.
I just reversed the two values of cc#23 (0 and 127) for the stop button in enigma and now its working. So in enigma value 1 should be 0 and value 2 127 ONLY for the stop button.
In the commands window in DP make sure that it reads #23 :0 in the MIDI event field, applying James hold&click trick, For all other settings follow the excellent instruction from James.
I guess MOTU has changed the behavior of the stop button slightly because running DP5 I never had that problem. A few days ago I upgraded to DP7 and the button stopped working.
Hope this helps.
matthis
Postby James Steele » Tue Oct 27, 2009 9:43 am
I haven't had time to revisit this subject, but my instructions worked for Oxygen keyboards. Axiom had a problem with Enigma. If you got this to work though that's fine. Main thing I found is that I had to increment a present up and done for changes made in Enigma to stick... or something similar. It's dicey.
As for the Axiom... I'd only do that from the front panel of the keyboard. One of these days I'll post a new tutorial.
JamesSteele.com | Dean Guitars | Facebook | Google+ | Twitter
2.66 Quad-Core MacPro (1,1), 7 GB RAM, OS 10.6.8, DP 8.01, MOTU HD192, 24I/O, UAD-2 Duo, Lucid GENx192, HV-3C, Red Type B, Dean guitars, Marshall amps, etc., etc.!
Postby IWood » Sun Dec 20, 2009 4:41 am
I'm running DP 4.61...will any of this work?
I was looking at an Axiom for use primarily as a MIDI controller, but if it will do fun stuff with DP as well that'd be a bonus.
DP 4.61
828 mkII (Firewire 1.2.4; MIDI 1.2.9)
OS X 10.4.11
Mini 1.25/80GB/1GB RAM
GLYPH GT050 120GB
IWood
Postby James Steele » Fri Jan 01, 2010 8:54 pm
IWood wrote:I'm running DP 4.61...will any of this work?
It should work, but the problem is you have to program the buttons from the front panel interface and can't use Enigma. For whatever reason the edits to the button parameters don't seem to "stick" using Enigma.
Postby IWood » Thu Mar 25, 2010 4:56 pm
James Steele wrote:It should work, but the problem is you have to program the buttons from the front panel interface and can't use Enigma. For whatever reason the edits to the button parameters don't seem to "stick" using Enigma.
Ooo tiny buttons for programming in a little display! Just like my first sequencer.
Just so I'm clear, here--"HyperControl" is just the featureset that allows me to assign controls to DP functions. "Enigma" is the software that *would* allow me to do that on my Mac *if* I had DP 6.x. So I can still get the control of DP 4.61 via the Axiom, I just have to create and save the setups via the keyboard itself, rather than the Mac. Yes?
Also: a related (but non-MOTU) question--can the PRO 61 output on all 16 MIDI channels, or just four, like its "non-PRO" sibling?
DP 4.61
OS X 10.4.11
GLYPH GT050 120GB
IWood
Postby James Steele » Sun Mar 28, 2010 2:30 pm
Okay, first of all not sure about "Hypercontrol." If that's something to do with the new Axiom Pro controllers, I know nothing about that. My post here was simply about how to make the transport buttons work with Digital Performer. Nothing more.
As far as Enigman goes-- that's a Macintosh App by M-Audio that is used to program settings on various M-Audio controllers like the Axion and Oxygen via an on-screen interface instead of from the front panel of the controller itself. What I found in my own experimentation is that Enigma worked okay with my Oxygen 49, but when I sold that and bought an Axiom 49, the Axiom would not retain the setups I created in Enigma. I was forced to enter them from the front panel of the Axiom 49.
Again, this was the Axiom and not the Axiom Pro. I know nothing about "hyper control."
Postby yoba72 » Tue Jun 01, 2010 7:57 pm
I finally got this to work... for me that is. I running dp7.12 and am using an Axiom 25 (not the pro version). The trick is to get your keyboard to send MIDI toggles which it doesn't initially have stored in its' 20 presets and thus since Enigma doesn't seem to talk well with the Axiom 25 (I haven't got them to work with each other) we need to do all the MIDI code edits on the keyboard itself. Fun!
Let's start with the STOP button.
1. press ADVANCED on your Axiom 25
2. press the STOP button
3. press Ctrl Assign (this is a white key button. Should be the note C) this should make the initials CC flash in the LED screen.
4. press 1, 4, 6, on the black keys (We need to enter 146 which is the code for MIDI CC TOGGLE, this is the secret code to not have you buttons stick or stay on forever in dp7 or any daw for that matter.)
5. press ENTER (should be last white key)
NEXT (abridged version)
1. press ADVANCED, press STOP, press DATA 1, press 2, 3, and then press ENTER
2. press ADVANCED, press STOP, press DATA 2, press 000, and then press ENTER
3. press ADVANCED, press STOP, press DATA 3, press 127, and the press ENTER
after all that... you should see a bunch of flashing numbers once you press the stop button. Basically it's toggle between On/Off and thus your stop button in dp turns on and off. Oh forgot to mention you'll still need to have dp learn the command so be sure to open it up (shift + L) and have the stop button learn the new command as stated earlier in this post.
It works for all buttons play, record, rewind, etc. But for fast forward and rewind I personally use the Pitch Bend. I don't use when I play so it comes in handy. Enjoy!!
yoba72
Postby ripeart » Thu Apr 21, 2011 9:05 pm
Just confirming the original instructions work flawlessly in my setup. DP 7.22 and Oxygen 24 v3. Thank you very much.
'11 MacBook Pro 10.6.8 i7, 8GB, DP 7.22 | Spectrasonics Omnisphere, Absynth, NI Komplete, Waves Mercury, Nugen, SoundToys
Dynaudio 6a, Avantone Mixcubes, Event 20/20, Focusrite ISA One, DBX 160x, DBX 386, DBX 1066, Mindprint, 828.2, Lexicon PCM-91, Oxygen 25, Yamaha P-85, Midisport 2x2
Neumann TLM-103, Rode NT1a, Fathead Ribbon, Fender, Gibson, Taylor acoustics, PRS & Schecter guits, Vox VT120+, GK-MB112, etc...
ripeart
Postby billgers » Wed Oct 19, 2011 6:37 pm
James-
I noticed that this thread addresses some of the issues that are related to my thread start earlier today about finding a good keyboard controller for DP. Do you know if the Oxygen can be used for more than just transport controls with DP? Can the sliders be used for mixing or can the knobs be mapped or cc control etc.? If so, is all of this a huge pain to program or is it relatively painless?
Thanks for your help!
-Bill
billgers
Postby James Steele » Wed Oct 19, 2011 7:42 pm
DP's faders and pan have MIDI Learn capabilities. Pretty sure you can assign CC's on the keyboard as well. Consult M-Audio manual. :)
Postby billgers » Wed Oct 19, 2011 8:10 pm
Thanks! I'll download the manual.
-Bil
billgers
Postby billgers » Wed Oct 19, 2011 10:53 pm
James-
I looked at both the commands menu and info in my DP manual and I looked at the Oxygen manual and couldn't figure out how the faders get mapped. Is the MIDI learn with the faders a pretty simple/straightforward process?
Thanks,
Bill
billgers
Postby mkoplin » Mon Nov 14, 2011 4:17 pm
It's been 3 years since this was originally posted, and I tried it.
I was able to set the commands in DP, but it's not working. I wonder if anyone could help me figure out why? I have an Axiom 25.
MacBook Pro, Intel Core 2 Duo, 2.4 GHz, 4GB
Mac Pro, Quad-Core Intel Xeon, 2.8 GHz. 2 Processors, 8 Core, 6 GB
Digital Performer 7.2, M-Audio Axiom 25, Yamaha CVP 305
mkoplin
Postby James Steele » Mon Nov 14, 2011 6:29 pm
You have to set up Axiom from the front panel... the settings didn't seem to "stick" when using Enigma. I don't really have time to try and walk you through it right now. :(
PreviousNext
Return to Digital Performer [MacOS]: Usage, Techniques, Tips & Optimization
Who is online
Users browsing this forum: toodamnhip and 5 guests
Who is online
In total there are 6 users online :: 1 registered, 0 hidden and 5 guests (based on users active over the past 5 minutes)
Most users ever online was 145 on Wed Oct 31, 2012 7:14 am
Login Form
