It is currently Fri May 24, 2013 1:16 am
Text Size
writing controllers on moving faders
Digital Perfomer in the context of television/film scoring and post-production.
Postby rukidding » Thu May 12, 2011 12:16 pm
I simply want to write ctlrs 1,11,3 & 4 info QUICKLY! on MOVING faders without going into graphic ed searching for current levels etc. I've found this http://www.jlcooper.com/_php/product.php?prod=fm4100
and I've read about the ipad2 and the AC-7 software. Which would be best? Any ideas?
Thanks, G
Mac12core, 10.6.8, DP7.24, 2408 mk III, VE Pro, UAD quad, Waves, NI and all the usual suspects
rukidding
Re: writing controllers on moving faders
Postby MIDI Life Crisis » Thu May 12, 2011 1:29 pm
Not sure I totally understand the question, but if I am understanding you...
When I want to write any non-standard controller (meaning not 1, 7, 10, 11, 64, etc) I set DP in record mode and move the controller (fader). Once there is some data in the sequence I can actually see, I then draw the data in the graphic editor as desired.
_______________________________________________________________________
_____________________________MIDI Life Crisis_____________________________
_____________ML.3 • DP 64 bit • 8 core MP/20GB RAM • Track 16______________
Postby rukidding » Thu May 12, 2011 3:46 pm
Yeah this drawing thing? :) is not what I call quick & breaks the creative process for me. If you have an orchestral template and you're writing at least 1 & 11 on lots of tracks you're talking about considerable time doing repetitive tasks. As much as I don't want to buy hardware I will if that's the only way to do this efficiently. The Cooper FM4/100 will do it but I'd rather have an iPad2... hence my original question. Thanks MLC
rukidding
Postby cowtothesky » Thu May 19, 2011 6:21 am
MIDI Life Crisis wrote:Not sure I totally understand the question, but if I am understanding you...
Yes, I do this as well and it is very repetitive. However, I usually don't use a controller fader. I just draw it in. Then, I have to 'create continuous data' to get it to sound smooth and not rigid. Is there a way to set DP to automatically create continuous data when you draw data initially? I hate having to go to a second step of drawing it, then highlighting the section, then clicking 'create continuous data'. It would be nice if it would create the continuous data when I initially draw the line and not have to do the 2nd step every time.
Imac 2.8 GHz Intel quad Core i7, 16GB Ram, Mac OS 10.6.7, DP 7.24, Motu Ultralite MK3 Hybrid, VSL Instruments, VE Pro, Vienna Suite, Spectrasonics, Project SAM, Kontakt, Korg M3
cowtothesky
Postby rukidding » Thu May 19, 2011 3:46 pm
I always set a reference point for every controller I'm going to use at the top of each sequence so it will write that kind of data if I double click on it and use any tool to draw it. I want to hear it in realtime though. It's music not script for God's sake and time doesn't permit all this mousing around. I think this is our boy http://www.jlcooper.com/_php/product.php?prod=fm4100
rukidding
Postby rukidding » Thu Jul 21, 2011 6:05 pm
still no compatability with DP!
rukidding
RESOLVED: writing controllers on moving faders
Postby rukidding » Tue Jul 26, 2011 4:42 pm
rukidding
Return to Digital Performer: Film/Video Scoring & Post Production
Who is online
Who is online
Login Form
