Set tempo range?
Set tempo range?
I'm still back on DP 5.0.
Is there any way to highlight a block of tempo markings and set their range? (say between 105-110bpm)
Fred
Fred
Mac Mini 2.26GHz Intel Core 2 Duo / 4Gb 1067 MHz DDR3 | OSX 10.5.6 | Lacie mini ext-HD 160GB 2MB Cache 7200rpm | DP 5.11 | Ivory | TruePiano | MOTU MSI | Kontakt | iMic audio i/o | M-Audio Keystation 88es | Stewart PA-100B PowerAmp | Yamaha NS-10M monitors | http://soundcloud.com/fredparoutaud/" onclick="window.open(this.href);return false;
Re: Set tempo range?
5.0? Your sig says 5.11 but if you are in DP 5 you really want to be at 5.13 as that was the best and last version in that release. You should be able to log into your MOTU account and download the right update.lamboguy wrote:I'm still back on DP 5.0.
Fred
Yes, you can easily do what you want:
In the DP 5 manual reference page 323 and get into that mode.
Then go to page 539 and apply that procedure to the tempo (selecting the values you want to constrain to). You may have to do this twice, once for low values, once for high values.
Pretty simple, huh? Please let us know how that works out for you. (No help from he trolls please - it can be so telling...)
Hey, cool! Thanks MLC, appreciate the help. And I will indeed upgrade to 5.13 (yes, I'm actually on 5.11, but am amazingly sloppy in my posts
Cheers,
Fred
Cheers,
Fred
Ok...I'm flailing.
I can select the tempo marks... no problem.
But when I go to Region/Change Continuous Data -- there's nothing mentioning tempo marks. Is there a controller number for them? (nothing in the index on that, that I can see)
Better yet, I actually read the pages in the manual! But I still can't find anything on how to do this.
Now I'll admit, I'm a really crappy reader. That's most certainly why I got into music.
Fred
Fred
Oopsy! My bad. You might try under the PROJECT menu: MODIFY CONDUCTOR TRACK > CHANGE TEMPO and then randomize within a range that fits your criteria. You might have to play around with it a bit (the percentages) but that sould be pretty close to what you're looking for.
You can also DRAW in the tempos quickly with the RESHAPE TOOL.
Sorry for the misstep on my part.
- Shooshie
Modify Conductor Track / Change Tempo
You can set a range in there, just as with velocity, continuous data, etc.
Shoosh
Shoosh
Ok, thanks guys.
I think the answer is "no, you can't do that."
At least, not the way I want to, which is to select the tempo marks, and maybe "limit to a low of 110" or something like that. Like you would change the velocity of group of notes, for example.
The other methods work great, I'm drawing lines all the time so that's no problem.
The deal is this (just to explain why I ask) -- I improvise lines in, then "Record Beats" to that, which ends up with a rather rough (tho good) tempo track. I like to keep the natural feeling of that, but also there are always tempo marks that are "a bit too low" or "a bit too high" and it would be nice to just see them, highlight them, and limit highs/lows.
But...that's life.
Fred
But...that's life.
Fred
- Shooshie
My apologies. I didn't have DP open, and for some reason I just spaced out. What I intended to write, and should have written, was "Region / Scale Tempos."
I've used it thousands of times. It does what you want.
That's what I was thinking. Of course that's also the difference between asking for a castration instead of a circumcision. One gets you what you want and the other leaves you with nothin!
