It is currently Sun May 19, 2013 8:36 pm
Text Size
DP: Using a clap track for sequence tempo
This forum is being developed and is intended as intended as a place to bring together various Digital Performer video tutorials. Currently only YouTube videos may be embedded using the [YouTube] BB code.
Postby strikingtwice » Thu Apr 28, 2011 11:53 am
Hi everyone. This is something that I often do when I have a freely recorded audio track, and I want to be able to edit a little bit better or add instruments. I feel like the record beats feature never leaves me with the results that I want, but this method does. It doesn't require nearly as much manual work as just starting with adjust beats right away. Hope it helps!
David DeLizza
4-core nehalem macpro, 6 gb ram, dp5,6,7, motu 896hd, axiom61, reason 4, bunch o' plugs.
strikingtwice
Re: Using a clap track for sequence tempo
Postby Dan Worley » Thu Apr 28, 2011 1:50 pm
Good job, David. Very useful and easy to follow. I tore my hair out trying to figure out how to do that one day and I never did get it right. You pointed out some things I've never noticed before in DP. Thanks so much for putting that together.
c-ya,
Dan Worley
DP8.0 • 10.6.8 • 3Ghz Mac Pro (4-core) 1st Gen. - 2006-2007 • 9GB RAM • ATI Radeon x1900
Dan Worley
Postby strikingtwice » Thu Apr 28, 2011 2:11 pm
Thanks Dan. I really want to try to use this part of the forum more and drive more traffic to it. The whole video took me about 15 minutes to put together, not including export and upload time. Please, pass it along, make some of your own, put the word out to get more of our super talented forum friends to use this section! Look on youtube for logic or protools tutorials, you get bombed, performer comes up very light!
David DeLizza
strikingtwice
Postby kwiz » Thu Apr 28, 2011 3:15 pm
Nice job, thanks for posting!
Great family and friends!
MacPro 3GHZ Quad Core, MacPro 2.66 Quad Core, MacBook Pro 2.53, OSX 10.7.3, DP 7.24, DP 8, PT 9.0.6, Logic Pro 9.xx, Motu 2408 MKIII, 828 MKII, 896 MKIII, Waves Diamond, Focusrite Liquid Mix, UAD1 & 2 cards. AMPGUI Sleek & Warm!
"Without struggle there is no progress"
F. Douglas
kwiz
Postby Shooshie » Thu Apr 28, 2011 6:45 pm
Great video, David! This has to be the best way to use DP's beat-finding feature. It eliminates the "just sorta" beats that compete with the real beats; it makes the beats clear; and BEST of all, it captures the feel of the beats. You'll clap where you would feel it, and no computer algorithm on earth can do that.
Good job on the video, too. May I ask what you used to make that? And what format did you end up putting it in? I'd like to know a decent format that captures the sharpness, keeps the file-size manageable for up/download, and that prevents audio drift when streamed or downloaded. My tutorial on Adjust Beats is an embarrassment because of the drifting audio. I'd export it to a different format if I knew the right one. If I can ever make this process fast and brainless, I'd upload a lot more videos.
|l| OS X 10.8.3 Mountain Lion |l| DP 8.01 |l| 2.4 GHz 12-Core MacPro 2012 |l| 12GB RAM |l| Mach5.3 |l| Logic Pro 8 |l| Waves 9.x |l| Nomad Factory Vintage Plugins 1.4 |l| Altiverb |l| Ivory 2 |l| Wallander WIVI 2.30 Winds, Brass, Saxes |l| Garritan Aria |l| VSL 4.1.8 |l| Yamaha WX-5 MIDI Wind Controller |l| Roland FC-300 |l|
Postby cowtothesky » Thu Apr 28, 2011 7:19 pm
Awesome video! Thanks for sharing your tips. I have only experimented with the adjust beats function and this video really opened up some doors for creating a MIDI grid using this feature. I agree with you, we need more of a presence with DP tutorial videos. As I get more confident with DP, I'll try to post some tips in the future. Thanks again, David.
Imac 2.8 GHz Intel quad Core i7, 16GB Ram, Mac OS 10.6.7, DP 7.24, Motu Ultralite MK3 Hybrid, VSL Instruments, VE Pro, Vienna Suite, Spectrasonics, Project SAM, Kontakt, Korg M3
cowtothesky
Postby Julia123 » Thu Apr 28, 2011 8:20 pm
Thanks!! I didn't know this could be done so smoothly!
iMac OS X 10.6.8, Dual Core, 3.06 GHz, 12g Ram, DP 8.01, Apogee One
Julia123
Postby strikingtwice » Thu Apr 28, 2011 8:28 pm
Shooshie wrote:Great video, David! This has to be the best way to use DP's beat-finding feature. It eliminates the "just sorta" beats that compete with the real beats; it makes the beats clear; and BEST of all, it captures the feel of the beats. You'll clap where you would feel it, and no computer algorithm on earth can do that.
Don't sweat it shoosh, in fact your video was the only reason I was ever able to grasp the concept, I couldn't get that out of the manual! The lag was tough, especially since it's about something as time sensitive as beats! At any rate, the program I used was http://www.telestream.net/screen-flow/overview.htm and I think it's by far the best for screen capture, but it is 99 bucks. Quicktime X will do screen capture, but it doesn't allow both input and system audio. The formatting was handled automatically by Screenflow in its youtube upload feature, and it allows for HD.
There is another program which is much cheaper for the regular version by http://www.shinywhitebox.com/store/shop.php. If you're looking for a good screencasting app but don't want to shell out 99 for it, this is the way to go.
Also, about the clap, it is much more natural than record beats. I've always found that to be unwieldy and not natural. My tempo is usually really good (this video not indicating), and when i clap, it's in, but when i use my MIDI controller or heaven forbid the mac keyboard, the timing is not even remotely close. At the cost of a few minutes and one pass through the song, I have something infinitely better. Check out those apps shoosh, I think we could start something really nice for the DP community! More vids! screw those Logic and PT youtube nerds!
David DeLizza
strikingtwice
ISHOWU is only $22 on Mac App Store!
Postby strikingtwice » Thu Apr 28, 2011 8:29 pm
I just checked after writing that post.
http://itunes.apple.com/us/app/ishowu/id417136885?mt=12
EDIT: Not the HD version. Also, check the demos to make sure that version does both incoming audio and mac audio.
David DeLizza
strikingtwice
Postby HCMarkus » Thu Apr 28, 2011 11:05 pm
Nice! Thanks David.
Postby Shooshie » Fri Apr 29, 2011 3:43 am
strikingtwice wrote:Don't sweat it shoosh, in fact your video was the only reason I was ever able to grasp the concept, I couldn't get that out of the manual! The lag was tough, especially since it's about something as time sensitive as beats! At any rate, the program I used was http://www.telestream.net/screen-flow/overview.htm and I think it's by far the best for screen capture, but it is 99 bucks. Quicktime X will do screen capture, but it doesn't allow both input and system audio. The formatting was handled automatically by Screenflow in its youtube upload feature, and it allows for HD.
I just bought ScreenFlow, David. Thanks for the tip. Now I can remake the Adjust Beats video and (I hope) rest easy that it the audio will not drift. The weird thing about that movie was that it was all perfectly in time before I uploaded it. Played exactly as it should. Then I'd upload it, and when I'd go to stream it, the audio would quickly get WAY out of sync with the video. I tried a half-dozen formats, and I uploaded it probably 10 times, thinking I did something to it, but it was none of those things. It started out a perfectly synced video, and only drifted out of sync once it was uploaded! I cannot figure that one out. Maybe someone here can. Anyway, I look forward to trying again with this app. I might even get in the mood to make more videos if I can be sure they will stay in sync!
Thanks again.
Shoosh
PS: Would you mind if I post your video in the Tips Sheet? I'd like to post it in the same message with mine (crediting you, of course), and giving people a more balanced view of these facets of DP. I was always going to do one like yours, more or less, but kept putting it off until I figured out how to correct that audio drift problem.
Postby strikingtwice » Fri Apr 29, 2011 7:01 am
Yea that's not a problem. I'm glad you purchased it, it really is a terrific app, and one more addition to the growing army of DP vids!
David DeLizza
strikingtwice
Postby Phil O » Fri Apr 29, 2011 7:11 am
Great job on the video, David! I've been using this technique for some time. I'm a percussionist, so I usually use a stick and a pad, but the results are the same. Where finer subdivisions are required I've also used a shaker with varying success (works best with faster tempi). I find this technique yields better results than record beats, hands down.
DP 7.24, Mac Pro 2.66 quad (6 Gig RAM), Mac Pro 2.8 octo, (12 Gig RAM), OS 10.6.8, two MOTU 828s, Apogee Rosetta 800, UAD-1e, UAD-2, a whole truckload of outboard gear and plug-ins, and a partridge in a pear tree.
Phil O
THANKS PHIL
Postby strikingtwice » Fri Apr 29, 2011 7:57 am
Phil O wrote:Great job on the video, David! I've been using this technique for some time. I'm a percussionist, so I usually use a stick and a pad, but the results are the same. Where finer subdivisions are required I've also used a shaker with varying success (works best with faster tempi). I find this technique yields better results than record beats, hands down.
SO IT WAS YOU! I was trying to think of whose post it was on nation that I read that caused me to start using this.
Thanks Phil!
David DeLizza
strikingtwice
Postby Phil O » Fri Apr 29, 2011 8:14 am
Wow! I was your inspiration and I didn't know it. :lol:
Anyway, you did a great job laying it all out. Thanks again for the video. The time folks put into making this board great is really appreciated.
Phil O
Next
Return to Digital Performer: Tutorial Videos
Who is online
Users browsing this forum: No registered users and 0 guests
Who is online
In total there are 0 users online :: 0 registered, 0 hidden and 0 guests (based on users active over the past 5 minutes)
Login Form
