DP can open and edit a Sysex, which is powerful, indeed.
But I can't find a way to export the edited sysex.
In case DP can't do it, any idea which app to look for such task?
If you wonder why I'm after this: I need to turn an X-Station patch into a V-Station patch.
a way to export edited sysex ?
- daniel.sneed
dAn Shakin' all over!
DP11.31, OS12.7.5, MacBookPro-i7-3.1Ghz-16GoRam-1ToSSD
Falcon, Kontakt, Ozone, RX, Unisum & Michelangelo, LX480, Sparkverb
Re: a way to export edited sysex ?
Save the sequence as a standard MIDI file and then change the file type extension to .syx.
- daniel.sneed
Wow ! Thanks 1npout0utput. This does work. And all inside DP!1nput0utput wrote:Save the sequence as a standard MIDI file and then change the file type extension to .syx.
