I am experiencing a rediculously long delay from MIDI in to MIDI out on record enabled tracks: 60+ seconds!!!!!
The level indicators in the Tracks window show MIDI activity as does the MIDI Monitor window but nothing sounds until a minute later!
It gets more bizar: if I record MIDI data appears on the track 60 seconds later than the playhead but not quite as played.
Tracks recorded before this problem play fine.
What is going on!?
I tested my setup in CoreMIDI and it responds fine. I fired up GarageBand and it responded in time also.
Has anybody experienced this?
60+ second delay on MIDI in
Never mind
The problem is gone. Even though I rebooted, turned every perifrial off/on the problem persisted until I cycled the power on my MTPAV while DP was running.
Still don't understand it but I know what to try first next time.
