I have been using D.P. 4.6 as a D.A.W. powered by my Digi 92 and 196 running in DAE mode. I've sold my mixer and have no problem mixing everything internally with this set up. However when I switch to MOTU audio mode and try to do this running my hardware synths into the MOTU 24 I/O I can't seem to figure out how to assign the outputs of the synths connected to the MOTU 24 I/O which is connected to the G5 by firewire so that I can record them onto a stereo audio track in D.P.
Does anyone have any ideas on this or use a similar set up??
thanks,
scooter
techy question about mixerless MOTU 24 I/O set up
Macbook Pro OS 10.12.6, 2.6 GHz Intel Core i7, 16 gig memory, Apollo Twin audio interface.
The 24i/o is a PCI setup. Even if there is a FW connection at the back , it's a MOTU protocol called "Audiowire" . You absolutely need to install a 424 PCI card in your G5 in order for that setup to work.
Motu has other FW units: 828 , 896 and the traveller.
If you bought it as an expension, maybe you can change it for a "core" unit...
I do have a PCI 424 card in my G5 originally for my 2408 mk3. Now I have the 2408mk3 and the 24 i/o plugged into the PCI 424 card via firewire or Audiowire.
My question is: how to record the synths plugged into the 24 i/o into D.P.?? I can monitor these synths, so I should be able to route them somehow to be able to record them. They're coming up in my cue mix at the main outs. But D.P. won't accept the main outs from cue mix to be used as a stereo input into D.P. to record. D.P. just doesn't see it. There must be way to tweak either the cue mix or maybe my audio bundles to be able to do this. But I haven't figured it out yet. I would be eternally grateful for some help on this!
