What would you like to see in the next BPM 1.5?
Moderator: ssp
Just curious of what others would like to see in the next version of BPM (1.6? 2.0?)... I have a few things myself I'd like to see...
Re: What would you like to see in the next BPM 1.5?
for me i would like to see these:
- fully implemented, bug free, unlimited undo/redo
- sort out note repeat, doesn't work on mine at all, appears to be a bug
- improve CPU usage, works very poorly in logic and i hear is not too good on other platforms
- chromatic pads
- personally i would like to see a larger pattern screen and smaller buttons
- fix all bugs, major and minor
- pdf manual of current version
- note nudge in user selectable increments
- improved implementation of quantize
- better communication from motu
- make it free
- don't introduce new bugs when fixing the old ones...
- chromatic pads
- make it free
OSX 10.6.4 / logic pro 9 / reason 5 / bias peak 6 / bpm 1.5 /
ive not had it long but after a serious ammount of studying and workng thru sessions with it there a few pros n cons!
id like to see:
+preset saving ,for user fx,lfos (like kontakt)
+much better looping (glitches and only cycles twice when looping!)
+END of the samping clip corruption bug!we need to sample its a sampler!!
+keyboard mode so you can use keys chromatically with pitch in the banks A-D like maschines (pad/keyboard) mode.
+MP3 IMPORT-unless its in 1.5?i only have-1.05
+maximun mapping so i could use maschines controller for everything -including slice marker etc
+a restart mode ,when u press stop it pauses halfway until you press again to get it back to the start,i think there should be an option for this (restart mode/button on maschine)
+resizable GUI-i have only 15 ""monitors for space and it takes up one and a haf monitors!maybe let have ooption to minimize views ie-no padview or sequencer view (custom).
until the next update theres always workarounds!love the engine,filters,fx and line templates and MIDI import!
if anyone can help on the above or have wokaraounds please let me know!!!
sappo
id like to see:
sappo
sappo wrote:ive not had it long but after a serious ammount of studying and workng thru sessions with it there a few pros n cons!
id like to see:
sappo
you really need to update to the current version, vastly improved user MIDI mapping. I use my BPM control unit and my maschine conroller with bpm.
Website: http://www.plastikaudio.btinternet.co.uk/
mac pro 8-core, mac mirror door dp, graphite g4 400.
Motu 2408/24io interfaces, PT HD, Event opals, Focal twin 6.
Too many synths to mention!
In rack mode when you highlight a slot you get a red line around it indicating that is is selected which is good. But in addition it gets grayed out. This greying out makes it hard to see the information inside it. Its hard to see if the mute and sole buttons are on or off and it makes the type which is almost microscopic in size even harder to read. Also it's just counter intuitive to have a selected item get grayed out.
My request would be that it simply gets the red line around it when selected which is obvious clean and clear.
http://www.invinciblemusic.com" onclick="window.open(this.href);return false;
