DP 7.2 - Full Screen Video window?
Digital Perfomer in the context of television/film scoring and post-production.
by Jera » Mon Feb 07, 2011 9:52 am
I'm still on DP 5.1, when you display video on a 2nd monitor you can't present the movie, you still get the window bar. Is this still the same in 7.2?
Chris
Chris
DP 7.24 / MacBook Pro 2.7ghz Core i7/8GB ram/1TB Firewire 800/828 original/Midisport 2X2/MIDI merger
- Jera
Re: DP 7.2 - Full Screen Video window?
by bricker » Mon Feb 07, 2011 4:02 pm
Yes. I usually just do a quick bounce and use Quicktime to present the movie in full screen.
- bricker
by Jera » Wed Feb 09, 2011 11:07 am
Does anyone have any experience with Pro Tools using video? I'm wondering if you can "present a movie" on a 2nd display and not have a window bar around the video.
Chris
Chris
- Jera
by elcappn » Thu Feb 10, 2011 6:15 pm
No, Pro Tools still has a bar across the top of the movie window. Logic (in 32-bit mode) and Cubase/Nuendo are the only mac DAWs that allow for true full screen video playback.
Chris
Mac Pro 2.66 14GB of RAM, 24" Dell Display x 3, OS X.7.5, DP 8.01, Logic 9.1.8, PT 10, Nuendo 5.5, Sibelius 7, Fireface 800, MTP AV, All Oxford plugs, URS CS Pro, N.I. Komplete 7, Ivory, EastWest, ProjectSam, SoundToys, LASS+LS, WIVI Brass+Winds, MachFive 3, BPM 1.5
- elcappn
by Jera » Fri Feb 11, 2011 1:46 pm
elcappn wrote:No, Pro Tools still has a bar across the top of the movie window. Logic (in 32-bit mode) and Cubase/Nuendo are the only mac DAWs that allow for true full screen video playback.
That's too bad. Logic would be perfect except it's not set up like DP where I can have multpiple sequences ready to go with Chunk chain. DP is set up in our live show where each song is a sequence and there is a movie file per sequence and the chunk list is esentially the set list for the night. Each sequnce fires off MIDI data for drums and lights and is synced to the movie file. Only problem is we get the DP bar across the video window. If I over stretch it enough I can usually shoot it over the top of the screen but would love to get rid of it.
Chris
- Jera
by dcr » Tue Feb 22, 2011 7:34 pm
you can get rid of it, by using a Firewire Analog/Digital Video Converter (this can be a Canopus ADVC110)
I have a question,
how do you put a movie file per sequence ???
I just can use ONE movie file in all my project.
David.
I have a question,
David.
- dcr
by stephentayler » Wed Feb 23, 2011 1:38 am
In the movie window mini menu, uncheck Use Same Movie for All Sequences
I wound up investing in a programme called VirtualVTR that allows QuickTime movies in any format to be presented and sync to incoming timecode. It works really well, but it's expensive.
Cheers
Stephen
Cheers
Stephen
Last edited by stephentayler on Fri Feb 25, 2011 12:16 pm, edited 1 time in total.
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
Mac Pro 8 Core 2.8Ghz 16Gb RAM, MacBook Pro, 2Gb RAM, OSX 10.8.2, DP 8.01, PT9.06, Logic 9.1.8, MOTU Traveler, Ultralite Mk 3 Hybrid, MC MIx, MOTU VIs, Waves, Izotope Everything, Spectrasonics, SoundToys, Slate, Softube, NI Vintage Compressors, spl Surround Monitor Controller, spl Auditor Headphone amp, Genelec 1031A, 1029 5.1 system, Sontronics Mics, iPad etc..
stephentayler - Posts: 2270
by dcr » Fri Feb 25, 2011 11:53 am
Hey thanks
With DP im able to play audio and video synchronized, if you want to project your video in a plasma or LCD or even a gigant LED screen you just send it through the firewire output. You don't need to invest in expensive software.
Cheers
David
Cheers
David
- dcr
by stephentayler » Fri Feb 25, 2011 12:15 pm
True for standard definition (DV) through FireWire, which I have been doing for years, but for any HD format you have to find another solution.
Cheers
Stephen
Cheers
Stephen
by agentry1 » Wed Jul 27, 2011 2:04 pm
Stephen, does Virtual VTR allow for scrubbing? Need something that will go frame by frame and sync perfectly to allow for finding hit points and such.
- agentry1
by Saintmatthew » Thu Aug 04, 2011 7:36 am
Chris
Live will do it too, but also has the one "song" at a time problem the others have. Really, the 1 chunk per song setlist concept is brilliant and puts DP miles ahead of anything else for live use in my opinion. I do the same thing live you're trying to do and had the same problem with the window bar. Get a firewire box (I got a pyro for like $115). They are 100% worth it, especially as they take a lot of work off your system.
Macbook 1.83Ghz Core 2 Duo 1.25 BG RAM OSX 10.6 DP6.03 MOTU 828 MkII Reaktor 5.5 Roland V-Drum kit
- Saintmatthew
• Page 1 of 1
Return to Digital Performer: Film/Video Scoring & Post Production
Who is online
- Board index
- The team • Delete all board cookies • Delete style cookies • All times are UTC - 7 hours
