Audiodesk 3, sample editor from ableton live
francis543
Post by francis543 »
Hi,
I am using Audiodesk 3 and Ableton Live.
Sometimes I use Audiodesk as master for mixing ableton-live in slave, that work perfectly.
Other use, ableton-live in stand alone, working on sample, in the Live clip view, I try to edit the sample in audiodesk (configurated in Live "file folder" preferences) and that's not working.
For example that work perfectly with audacity.
Is there something to configurate in audiodesk, or this sample editing is forbidden in audiodesk ?
Macbook pro, Ultralite MK3 hybrid, M-audio axiom 49, KRK VTX4, Live Lite 8, Audiodesk 3
carrythebanner
Re: Audiodesk 3, sample editor from ableton live
Post by carrythebanner »
AudioDesk just doesn't really function as a sample editor in that same way. AudioDesk opens project files that use audio files, rather than directly opening an audio file and only an audio file.
That doesn't mean that you couldn't take audio from Live and process it in AudioDesk, it just means that AudioDesk isn't really designed for the exact workflow you're describing.
francis543
Thank a lot for your response.
I was going on to have the same conclusion thru investigations.
I'm going to find true editor.
