I just purchased a new G5 Dual 1.8, loaded DP 4.5 and then my Mach 5. The installation of the Mach 5 looked like it was succesful but I can't find it with my plug ins. I just switched over from Slow Tools to DP and need help.
Installed Mach 5 where is it?
Re: Installed Mach 5 where is it?
Hello
To open up the mach 5, go to the projects menu > intrument track and select the Mach 5. This will open up the Mach five instrument track which will act as an audio track with the plug in inserted. You will then proceed as usual and create a MIDI track and set output to MACH 5 1-1, 1-2, etc.
--Bryan--
--Bryan--
http://www.dfabstudios.com/" onclick="window.open(this.href);return false;
http://www.dfabmusic.com/" onclick="window.open(this.href);return false;
Chapter 66 on Virtual Instruments in the DP manual will talk you through this. It's probably in your DP online help as well.
In short:
Project Menu > Add Track > Instrument Track
Then hook up a MIDI track to drive M5.
In short:
Thanks for the info. I'll give it a shot tonight.
