Can anyone suggest something to try?
I've lost the connection between BPM and it's samples in the browser [ load perfs works ok ], I've redone the alias thing but it still doesn't work?
[ mac's are rubbush nowadays, grumble, etc... ]
no samples in the browser, even after doing the alias thing?
Moderator: ssp
Re: no samples in the browser, even after doing the alias th
On Windows here but make sure your alias is referencing the right location. If you moved or reinstalled then you want to delete the old alias and make a new one. You have to rename the alias so it is identical to the original ufs files. Remember there are two ufs files so you will need two aliases.
When you copy the aliases make sure you do them 1 at a time.I copied both at the same time and it did not work
I found the solution in the end, had to delete all BPM samples and copy the original sounds from the install disk as clean copies.
still a mystery why it went wrong in the first place??
