How do you record a song(sequence of 'scenes' in song mode) as a track in DP when using BPM as a plug-in in DP? I can get it to play back along with other audio tracks in DP, but the BPM notes aren't represented as MIDI or audio notes anywhere in the DP track. I'm making my 'scenes' in BPM using the step sequencer. I can't bounce to disk unless the BPM track is represented as audio on a track in DP.
Recording BPM as track in DP 7
Moderator: ssp
Re: Recording BPM as track in DP 7
That's not accurate, in my experience. In DP 7.1, when I make a time range selection in the BPM instrument track and Bounce to Disk, my sequences in BPM are rendered as audio as expected.jsheitert wrote: I can't bounce to disk unless the BPM track is represented as audio on a track in DP.
Carry-
Thank you... I'd try again, but I'm getting an error message with regard to the L.A.M.E framework...."can't open file".
The LAME framework is only for exporting/bouncing as an MP3, so try bouncing as something other than MP3 — AIFF, WAVE, etc. If that works, Google "LAME framework mac" and try to find a newer or different version of the LAME framework.
