Hi Folks,
I'm using MSI all the time, along with Kontakt. Kontakt has a "Purge" function to drop all the samples not being played in the piece, thereby freeing up memory.
Does MSI have anything like that?
Also, my MSI is c.2005, are there any updates I should be aware of?
Fred
Does MSI have "Purge?"
Mac Mini 2.26GHz Intel Core 2 Duo / 4Gb 1067 MHz DDR3 | OSX 10.5.6 | Lacie mini ext-HD 160GB 2MB Cache 7200rpm | DP 5.11 | Ivory | TruePiano | MOTU MSI | Kontakt | iMic audio i/o | M-Audio Keystation 88es | Stewart PA-100B PowerAmp | Yamaha NS-10M monitors | http://soundcloud.com/fredparoutaud/" onclick="window.open(this.href);return false;
Re: Does MSI have "Purge?"
You can toggle disk streaming independently for each part (under Expert Mode > Streaming), which can help to manage RAM usage, but there's no "Purge" command like you're talking about.lamboguy wrote:I'm using MSI all the time, along with Kontakt. Kontakt has a "Purge" function to drop all the samples not being played in the piece, thereby freeing up memory.
Latest MSI is version 1.1.3, released late 2006 (Mac) / early 2007 (Windows).lamboguy wrote:Also, my MSI is c.2005, are there any updates I should be aware of?
ty ctb!
Fred
Fred
